Oversize pricing, advice?
Discussion in 'Flatbed Trucking Forum' started by DDlighttruck, Jun 26, 2016.
  1. DDlighttruck
    DDlighttruck Road Train Member
    1,386
    19,918
    Dec 12, 2015
    There's been a couple threads in the past couple months, but they haven't really given me much help. I think where I'm stuck is the "office" side of things. I think it would be easy to say $3 per mile, once you have to pull a permit, THEN add "X" for the back office work.
    So, 22' by 12' bean planter. I have asked for height, but I don't expect it to be overheight. it will be going from a farm, to a farm. I'm expecting help on both ends to load/unload. I would have to deadhead 60-80 miles there, pick up, load, drive the 200 miles to deliver, then deadhead 100 miles home.
    So, based on past experience, I'll say 6 hours office work to pull the permits. 6 x $20 = $120. Good starting point? 400 miles x $3 mile = $1200. So $1320, the permit costs $65, so $1385. That seems pricey. If I drop to $2 per mile, it's still $985.
    I'm still learning, I'd like to keep the customer, but I don't want to work for free/too cheaply. And I want more experience running OSOW. So do I run a bit cheaper, to gain experience, or try to pop full rate to make money, AND get experience, but risk losing the load?
  3. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    Depends on if this is a regular customer, or a one shot deal.Rather hard to charge for time to obtain permits.
    If you do it cheap once, you will be expected to do it cheap all the time. Escort ? That would be extra.
    I would like to charge $2.75 for every mile run, and cost of permits. Or a flat 100 bucks an hour, start to finish, plus permits.
    DDlighttruck Thanks this.
  4. m16ty
    m16ty Road Train Member
    2,265
    4,942
    Jan 22, 2016
    I don't see how it would take 6 hr to pull a 12' wide permit, it would take me all of 10 minutes if it's just one state. 1,385 is still cheaper than I'd do it but that's just me.
    If I can't get $120 hr for legal loads and $140 hr + permits for oversize, my truck sits. That load is going to take you 10 hrs minimum.
    Faizenberg, Ruthless and DDlighttruck Thank this.
  5. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Try getting a 12' wide permit for NY state. Its a grab bag,.. 24 hours to 3 days has been my experience. Getting a Thru-way permit took me 20 mins for 11' wide. Go figure.
    Hurst
    Lepton1 and DDlighttruck Thank this.
  6. TripleSix
    127,948
    Time. That's what you're trying to figure out. How much time will I have tied up on this load? See, I like to see minimum $1000/day. From the time I start until the time I am ready to grab my next load.
    Can't do the straight $3/mile rate because sometimes, $3/mile won't pay for my time. Say for example, you have a regular contracted customer in Charlotte,NC. Customer has a load, oversized and 14'8 tall, 11 wide and 14000 going to GilletteWY. How much time would you have tied up on that load?
  7. m16ty
    2,265
    4,942
    Jan 22, 2016
    I have to admit, never been to NY and have no desire to go.
    I figure everything on time. At the end of the day that's all that matters to me. You can charge $5 a mile but if you only get 100 miles, for whatever reason, you not doing too well.
    You want that load tarped? Sure but you are going to pay $120 per hr for me to tarp it.
  8. DDlighttruck
    1,386
    19,918
    Dec 12, 2015
    I'm not sure if that was meant rhetorically, but I do know I would have no business bidding on it.
    Cheyenne to Gillette is 1800 miles. 3 1/2 days drive. 1/2 day to load, 1/2 day to unload. It would take me a day to route that, order permits, and order pilot cars. You didn't provide a length, so I'll assume it's under super load length. NC requires one pilot with a height pole for over 14'5". And, depending on when it's loaded, and weekend restrictions, you may have to sit for a day or two.
    So 7 days ($7000) plus escort and permit costs. Close?
  9. DDlighttruck
    1,386
    19,918
    Dec 12, 2015
    The first time was amateur hour. For single trip permits they need to know the route, exactly from address 1 to address 2. I had no idea how to fill out the form correctly, I was using someone's else's trailer, had to "guess" at the axle spacings. Two or three phone calls from the permit office, resubmitting the application, couple emails in there, driving to a fax machine, it all adds up.
    They told me if I get an annual permit I don't need to provide routing every time.
    Interesting view on the hourly. I'll have to start looking at things differently. Thank you
  10. Ruthless
    Ruthless Road Train Member
    8,786
    85,958
    Aug 28, 2010
    The City.
    Next time you know you'll be doing one pm me I'll give you my permit services phone number. Ny Nys thruway are 6 hours tops in my experience. I do them for same/next day all the time. Unless it needs a route survey, then it's longer obviously
    Lepton1 and Hurst Thank this.
  11. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I use Mercury Permit services. Christine is my go to with them. She is always on the ball,.. if there are any hang ups,.. its at the red tape end.
    Hurst
    Lepton1 Thanks this.
