Oversize permit requirement
Discussion in 'Flatbed Trucking Forum' started by mitmaks, Nov 23, 2017.
  1. mitmaks
    mitmaks Road Train Member
    2,542
    2,064
    May 16, 2014
    What's the limit for overhang on the back of 48ft trailer before I need oversize permit?
  3. kylefitzy
    kylefitzy Road Train Member
    4,596
    18,980
    Aug 12, 2007
    Kansas city,Mo
    Depends on the state. I would say 4' is safe pretty much everywhere. Also this advice is worth exactly what you paid for it.
    cke Thanks this.
  4. Jumbo
    Jumbo Road Train Member
    3,669
    7,389
    Sep 4, 2009
    Appleton, Wisconsin
    I would concur with your answer.
    cke Thanks this.
  5. Tb0n3
    Tb0n3 Road Train Member
    4,278
    8,194
    Oct 5, 2012
    Earth
    Some states is zero overhang and others it's half the load. Huge variance.
    cke Thanks this.
  6. Gunner75
    Gunner75 Road Train Member
    5,701
    9,073
    Mar 17, 2014
    Jackson Center Ohio
  7. ChaoSS
    ChaoSS Road Train Member
    3,338
    6,755
    Sep 20, 2014
    Every state has it's own laws. Also, it may depend on the freight and whether it's divisible. Just by example, here in California, on STAA routes, you are limited to 75' overall length. So if you are running a long setup that's that long by itself, you don't get any overhang at all. My setup is about 74 feet, but if I move the fifth wheel forward I can give myself a little more room for loads like plastic pipe. You are also limited to 2/3rds of the wheelbase, measured from the rear tractor axle to rear trailer axle, mine gives me about 27 feet of legal overhang, but overhang is measured not from the back of the trailer, but from the last point of support. Structural pieces (beams, poles, pipes, etc.) is exempt under 80 feet from the 75 feet thing, but not the overhang. So I can haul pieces up to 80 feet long with no permits whatsoever, so long as I keep the overhang legal. (and I can).
    Other states have different rules, measured in different ways. Some may not allow any overhang at all, or very limited, others allow up to certain amounts, so you can let that lumber load, or plastic pipe, hang off a few feet. Others you can't do that, overhang will only be allowed if it's a non divisible load, and must be permitted.
    blairandgretchen Thanks this.
  8. Old Man
    Old Man Road Train Member
    4,597
    13,469
    Apr 3, 2009
    Oklahoma City, OK
  9. blairandgretchen
    13,212
    70,208
    Dec 9, 2011
    South west Missouri
    Note ‘ non divisible ‘ - most states are fairly generous with overhang for non divisible loads.
    Also ‘items of structural nature’ - encompasses a broad range of products, if it can’t be shipped as a shorter length, gives a lot of leeway.
    Note ‘overall length ‘ - Missouri for example is 90’ - which I quickly reach with the large car. Escort required on 2-lane roads. Though not specified, after running an auto-issue permit, found the escort is not required on the interstate, as yet - the upper limit is still unknown. Unhelpful when trying to quickly price long pieces. Guess I’ll find out one day.
    Missouri is also zero overhang on a 53’ without permit.
    The links above will give some effective narcoleptic reading material.
    Standardization would be great.
