Oversize Load information
Discussion in 'Heavy Haul Trucking Forum' started by UltraZero, Oct 22, 2014.
  1. UltraZero
    UltraZero Medium Load Member
    406
    96
    Jul 18, 2013
    Good evening. Regarding oversized loads, where can I find information regarding what equipment is needed. I am asking regarding 10Foot width
    loads with maybe a few feet of overhang.
    I understand each state/county if going off the main highway has their own restrictions.
    Regarding flags, does the color matter?? Red or Orange.
    Regarding flashers, same issue. Red or Orange.
    Lastly, same issue with Canada?? (I know, ouch) I think there is a different banner for Canada. (bid D in the middle)
    I also get some states only allow driving during certain times of the day and also some don't allow weekends.
    I also understand some states require a pilot car depending on how much overhang front and rear. Each state is different,
    but some are the same.
    Please let me know what you think...
    Thanks much
    Have a great evening..
  3. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
  4. UltraZero
    406
    96
    Jul 18, 2013
    Thanks much for the information. I appreciate it.
    Only, how do I find out about the oversize truck load regarding flags. What color red or orange? Also, how many on the load.
    Thanks
  5. ramblingman
    ramblingman Road Train Member
    1,152
    1,115
    Jan 12, 2014
    Red,You need to have flags at the outermost point of the load on all 4 corners at a minimum.
  6. G/MAN
    G/MAN Road Train Member
    7,031
    8,621
    Sep 3, 2010
    I prefer red flags, but have used orange. Either will work as long as they are large enough. You need flags on the front of your truck as well as on each corner of the load. You need an oversize load sign on the front of the truck and rear of the trailer. Flashing lights should be amber. Your permit should tell you about placement. I usually have one on the rear of my trailer and on the truck. Having a light on the truck may or may not be necessary. If you plan on running through Georgia, you need to make sure you have a permit for the lights. Read over your permits very carefully and follow their directions exactly as written. Laws concerning oversize loads differs with each state. Most will allow up to a 4' overhang without a permit or escort. Most states don't require an escort for loads that are 12' wide or less. Find a good permit service. They can be a good resource.
  7. UltraZero
    406
    96
    Jul 18, 2013
    regarding flags, are there differences in size between the US and Canada??
    18" flags in the US and 24" Flags in Canada?? Also the front and rear banners have a big "D" in them??
    Thanks.
  8. macmanboomer
    macmanboomer Light Load Member
    72
    56
    Oct 19, 2014
    TN
    All of the Canadian permits I've had allowed you to use either banner.
    I always flag mine the same way, to the max, so I don't have to remember to stop & change something before crossing into another state.
    You can get an oversize guide book from the truck stops that gives you a very good idea of what each state requires. However, the actual permit overrules everything so make sure you read each permit closely to be sure.
  9. UltraZero
    406
    96
    Jul 18, 2013
    Excellent. I have a permit book. I have not had time to go through it. I saw it at truck stop and picked it up knowing I was planning to pull oversized when the company allows me to. 1 more month. I figured I try to start to get a jump on what I will run into with a 10' wide load.
    Ah. Question. Regarding an oversized load (10 ft wide) is the driver to stick to a route plan??? on highway and off??
    I know there are issues with size so I could see why you would need to follow a route plan but, just want to make sure. I would think 10ft wouldn't be too bad. When you get into the 14ft width and longer lengths, I could see a problem.
    Thanks
  10. haulhand
    haulhand Road Train Member
    Yep most states issue a route even at 10 wide and under whether you follow said route or not is entirely up to you just don't get caught off route or god forbid have an accident while off route as they'll say you should have never been there in the first place so you shouldn't have been involved in the crash. Routes get fun when you start adding much height especially back east.
    281ric Thanks this.
  11. macmanboomer
    72
    56
    Oct 19, 2014
    TN
    Yes, you're required to follow the routing listed on the permit. If you get caught driving off route not only will you be in trouble, your permits are then voided. That means you're sitting on the side of the road till you get new permits issued.
    Most states allow you to go off route up to 1/2 to 1 mile for fuel, however, some states (Ohio for example) you have to have any stops included in the permit routing.
    281ric Thanks this.
