Oversize Load Hauling Wind Turbine Blade Laid Over
Discussion in 'Trucking Accidents' started by mjd4277, Oct 6, 2020.
  1. mjd4277
    mjd4277 Road Train Member
    13,886
    41,473
    Oct 4, 2015
    Fitchburg,MA
  3. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Hopefully that wasn't @TripleSix Or is he even still doing blades?
  4. 062
    062 Road Train Member
    6,142
    33,155
    Oct 20, 2013
  5. Rontonio
    Rontonio Road Train Member
    6,248
    45,378
    Aug 9, 2009
    I do not know the driver but it looks. Rey much like a double schnabel tower truck from lone star - and based on Where it happened - likely came out of either Brownsville where I am loading or maybe Port Aransas.
    no idea what happened in this case. It does bring home how fast this job can go very bad.
  6. TripleSix
    127,950
    That’s an incredible amount of torque when a schnauble rolls. When the regen setups first came out, had a friend get a brand new truck, and had to regen after jaking out of the mountains. He pulled on the shoulder and the shoulder gave way. The tractor got lifted up and power slammed. The blades aren’t nowhere’s near as heavy but the sheer size is more than enough to slam a tractor.
    Speaking of the tubes, since the blades are now 100 ft longer than they were, did they increase the size of the tower tubes?
    Bud A. Thanks this.
  7. Rontonio
    6,248
    45,378
    Aug 9, 2009
    Funny you mention tubes... i am looking at a half schnabel set up for next year
    The towers seem like mostly 5 piece setups now
    Top
    Upper mid
    Lower mid
    Upper base
    Lower base
    Bud A. Thanks this.
  8. TripleSix
    127,950
    Over 350ft tall? That lower base has to be over 20-25ft in diameter? The old ones were what...17ft in diameter and 230k on 13 axles?
    Bud A. Thanks this.
  9. Rontonio
    6,248
    45,378
    Aug 9, 2009
    no the upper base was under 15 wide but I am not sure what the bug lowers are - I know that max out a 13 axle so close to 260k gross
    well when the blades are 240+ ft long the tower has to be stupid tall
  10. TripleSix
    127,950
    I am glad things are working out so well for you and your crew. I like the half schnaubles too. Lot LESS complicated.
    You and Zoe going home Thanksgiving?
  11. Rontonio
    6,248
    45,378
    Aug 9, 2009
