Last week I was driving a truck in Michigan for a friend whose mother had passed away, the trailer was a high mount carhauler ,it was loaded when I got the truck, I was pulled over for being overlength for the top front car, as it was a normal 5th wheel trailer (high mount) the car was behind the sleeper,does anyone know regs on this,seeing as it didnt increase my overall length I think this is a weak ticket.
Overlength ticket
Discussion in 'Trucking Industry Regulations' started by junkyardhound, May 20, 2009.
Page 1 of 3
Does the tricket indicate what reg number it was written under?
Dominick253 Thanks this. -
It was probably written under either 480.17 or 257.719 of the MCL (Michigan Compiled Laws). 480.17 is a catch-all that defines a misdemeanor. Here's the rule
From a retired federal DOT official
257.719 Height of vehicle; liability for damage to bridge or viaduct; normal length maximum; prohibitions; connecting assemblies and lighting devices; gross weight; violation as civil infraction; applicability of subsections (2)(a) and (3)(b); definitions. Sec. 719.
(1) A vehicle unloaded or with load shall not exceed a height of 13 feet 6 inches. The owner of a vehicle that collides with a lawfully established bridge or viaduct is liable for all damage and injury resulting from a collision caused by the height of the vehicle, whether the clearance of the bridge or viaduct is posted or not.
(2) Lengths described in this subsection shall be known as the normal length maximum. Except as provided in subsection (3), the following vehicles and combinations of vehicles shall not be operated on a highway in this state in excess of these lengths:
(a) Subject to subsection, any single vehicle: 40 feet; a crib vehicle on which logs are loaded lengthwise of the vehicle: 42.5 feet; any single bus or motor home: 45 feet.
(b) Articulated buses: 65 feet.
(c) Notwithstanding any other provision of this section, a combination of a truck and semitrailer or trailer, or a truck tractor, semitrailer, and trailer, or truck tractor and semitrailer or trailer, designed and used exclusively to transport assembled motor vehicles or bodies, recreational vehicles, or boats, that does not exceed a length of 65 feet. Stinger-steered combinations shall not exceed a length of 75 feet. The load on the combinations of vehicles described in this subdivision may extend an additional 3 feet beyond the front and 4 feet beyond the rear of the combinations of vehicles. Retractable extensions used to support and secure the load that do not extend beyond the allowable overhang for the front and rear shall not be included in determining length of a loaded vehicle or vehicle combination.
(d) Truck tractor and semitrailer combinations: no overall length, the semitrailer not to exceed 50 feet.
(e) Truck and semitrailer or trailer: 59 feet.
(f) Except as provided in subdivision (g), truck tractor, semitrailer, and trailer, or truck tractor and 2 semitrailers: 59 feet.
(g) A truck tractor, semitrailer, and trailer, or a truck tractor and 2 semitrailers, in which no semitrailer or trailer is more than 28-1/2 feet long: 65 feet. This subdivision only applies while the vehicle is being used for a business purpose reasonably related to picking up or delivering a load and only if each semitrailer or trailer is equipped with a device or system capable of mechanically dumping construction materials or dumping construction materials by force of gravity.
(h) More than 1 motor vehicle, wholly or partially assembled, in combination, utilizing 1 tow bar or 3 saddle mounts with full mount mechanisms and utilizing the motive power of 1 of the vehicles in combination, not to exceed 55 feet.
(3) Notwithstanding subsection (2), the following vehicles and combinations of vehicles shall not be operated on a designated highway of this state in excess of these lengths:
(a) Truck tractor and semitrailer combinations: no overall length limit, the semitrailer not to exceed 53 feet. All semitrailers longer than 50 feet shall have a wheelbase of 37.5 to 40.5 feet plus or minus 0.5 feet, measured from the kingpin coupling to the center of the rear axle or the center of the rear axle assembly. A semitrailer with a length longer than 50 feet shall not operate with more than 3 axles on the semitrailer. City, village, or county authorities may prohibit stops of vehicles with a semitrailer longer than 50 feet within their jurisdiction unless the stop occurs along appropriately designated routes, or is necessary for emergency purposes or to reach shippers, receivers, warehouses, and terminals along designated routes.
(b) Truck and semitrailer or trailer combinations: 65 feet, except that a person may operate a truck and semitrailer or trailer designed and used to transport saw logs, pulpwood, and tree length poles that does not exceed an overall length of 70 feet or a crib vehicle and semitrailer or trailer designed and used to transport saw logs that does not exceed an overall length of 75 feet. A crib vehicle and semitrailer or trailer designed to and used to transport saw logs shall not exceed a gross vehicle weight of 164,000 pounds. A person may operate a truck tractor and semitrailer designed and used to transport saw logs, pulpwood, and tree length wooden poles with a load overhang to the rear of the semitrailer which does not exceed 6 feet if the semitrailer does not exceed 50 feet in length.
(c) Truck tractor and 2 semitrailers, or truck tractor, semitrailer, and trailer combinations: no overall length limit, if the length of each semitrailer or trailer does not exceed 28-1/2 feet each, or the overall length of the semitrailer and trailer, or 2 semitrailers as measured from the front of the first towed unit to the rear of the second towed unit while the units are coupled together does not exceed 58 feet.
(d) More than 1 motor vehicle, wholly or partially assembled, in combination, utilizing 1 tow bar or 3 saddle mounts with full mount mechanisms and utilizing the motive power of 1 of the vehicles in combination, not to exceed 75 feet.
(4) The following combinations and movements are prohibited:
(a) A truck shall not haul more than 1 trailer or semitrailer, and a truck tractor shall not haul more than 2 semitrailers or 1 semitrailer and 1 trailer in combination at any 1 time, except that a farm tractor may haul 2 wagons or trailers, or garbage and refuse haulers may, during daylight hours, haul up to 4 trailers for garbage and refuse collection purposes, not exceeding in any combination a total length of 55 feet and at a speed limit not to exceed 15 miles per hour.
(b) A combination of vehicles or a vehicle shall not have more than 11 axles, except when operating under a valid permit issued by the state transportation department or a local authority with respect to a highway under its jurisdiction.
(c) Any combination of vehicles not specifically authorized under this section is prohibited.
(d) A combination of 2 semitrailers pulled by a truck tractor, unless each semitrailer uses a fifth wheel connecting assembly which conforms to the requirements of the motor carrier safety act of 1963, 1963 PA 181, MCL 480.11 to 480.22.
(e) A vehicle or a combination of vehicles shall not carry a load extending more than 3 feet beyond the front of the lead vehicle.
(f) A vehicle described in subsections (2)(e) and (3)(d) employing triple saddle mounts unless all wheels that are in contact with the roadway have operating brakes.
(5) All combinations of vehicles under this section shall employ connecting assemblies and lighting devices that are in compliance with the motor carrier safety act of 1963, 1963 PA 181, MCL 480.11 to 480.22.
(6) The total gross weight of a truck tractor, semitrailer, and trailer combination or a truck tractor and 2 semitrailers combination that exceeds 59 feet in length shall not exceed a ratio of 400 pounds per engine net horsepower delivered to clutch or its equivalent specified in the handbook published by the society of automotive engineers, inc. (SAE), 1977 edition.
(7) A person who violates this section is responsible for a civil infraction. The owner of the vehicle may be charged with a violation of this section.
The provisions in subsections (2)(a) and (3)(b) prescribing the length of a crib vehicle on which logs are loaded lengthwise do not apply unless section 127(d) of title 23 of the United States Code, 23 USC 127, is amended to allow crib vehicles carrying logs to be loaded as described in this section.
(9) As used in this section:
(a) "Designated highway" means a highway approved by the state transportation department or a local authority with respect to a highway under its jurisdiction.
(b) "Length" means the total length of a vehicle, or combination of vehicles, including any load the vehicle is carrying. Length does not include devices described in 23 CFR 658.16 and 23 CFR part 658, appendix d. 23 CFR 658.16 and 23 CFR part 658, appendix d, as on file with the secretary of state are adopted by reference. A safety or energy conservation device shall be excluded from a determination of length only if it is not designed or used for the carrying of cargo, freight, or equipment. Semitrailers and trailers shall be measured from the front vertical plane of the foremost transverse load supporting structure to the rearmost transverse load supporting structure. Vehicle components not excluded by law shall be included in the measurement of the length, height, and width of the vehicle.
(c) "Stinger-steered combinations" means a truck tractor and semitrailer combination in which the fifth wheel is located on a drop frame located behind and below the rearmost axle of the power unit.Last edited: May 21, 2009
01blackz28 and Working Class Patriot Thank this. -
so a 53 foot trailer isnt legal in michigan? -
This rule has nothing to do with 53' trailers. That is a separate issue and that information was not requested in this original post.
i dont remember saying it did have anything to do with this issue
i was just wondering about that rule -
Freebird, for what its worth, 53's are legal in MI.
If it was written under 257.719 i would think its a weak ticket,
especially if the top car was behind the sleeper, the only other thing i can think of is you had to much hanging off the rear.
Take pics of the truck loaded and fight it. -
This does seem to be a pretty weak ticket if Junkyardhound was meeting the overall vehicle length requirements. As stated for most length laws, the load can extend 4' over the rear and 3' over the front, which means past the front bumper of the tractor. Since the car hauler didn't even make it to the sleeper, than this should be no contest.
can you give me more info.
Page 1 of 3
