Over height question
Discussion in 'Flatbed Trucking Forum' started by God prefers Diesels, Sep 4, 2021.
  1. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    A friend of mine, Dod prefers Giesels, managed to load 13' 10" in Cali, going to Michigan. Well, he kept meaning to check his load height for posterity, even though he knew it was under 13' 6"...
    So he finally decides to measure it in Kingdom City, MO. Wow, was that ####### wrong!!
    Now one could argue the load is divisible. He told me he's decided to run it anyway. (Dude is such a F'n outlaw)
    If he were to get back on:
    70 in Kingdom City
    270 around STL
    465 around Indianapolis
    69 to 469 around Ft. Wayne
    24 to 475 around Perrysburg
    And then 75 through Detroit
    Would my friend have any issues with a low overpass? He has already checked his route in the atlas. However these states are 13' 6" max, so anything higher than that isn't listed as "low". So there's a four inch gray area.
    I told him the one time you drop the ball is when you end up getting caught with your pants down. I'm just glad I'm not in his shoes right now!
    cke, tiddlytanker, D.Tibbitt and 10 others Thank this.
  3. Short Fuse EOD
    2,747
    8,545
    Jul 29, 2015
    Midwest
    Be careful with Detroit I believe there’s a 1310 there.
    cke, D.Tibbitt, mitrucker and 4 others Thank this.
  4. stuckinthemud
    stuckinthemud Medium Load Member
    620
    3,063
    Oct 20, 2013
  5. Dadetrucking305
    Dadetrucking305 Heavy Load Member
    980
    2,580
    Sep 15, 2011
    Cibolo,Texas
    Send her lol.
  6. N00bLaLoosh
    N00bLaLoosh Road Train Member
    1,027
    8,024
    May 13, 2021
    Novi, MI
    Where are you going in Detroit? City or suburbs?
    cke and God prefers Diesels Thank this.
  7. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    I have ran the route through Hammer at 13' 10", and checked the atlas. (which is sadly useless in this particular case)
    I can't use Smart Truck Route, because I already burned my free trial.
    North of it in Rochester Hills. The interstate will almost get me to the receiver's door.
    cke and stuckinthemud Thank this.
  8. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    I've also checked all the roads in this PDF:
  9. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    I'm not terribly worried about the cops, because it's the weekend, it's a holiday, and it's been raining since 3am and hasn't stopped yet in the last 400 miles.
    But what I am worried about is making a bad situation even worse by actually hitting something. I mean I'm vigilant (generally), but I'm also not used to being so high. All it takes is one lapse in attention to end up in the Hall of Shame. Ounce of prevention is worth a pound of cure.
    cke, Nostalgic and stuckinthemud Thank this.
  10. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Check the routing for a high route on the states permit sites.
    Holiday weekend, most scales will be closed. Most bypass belt lines have higher clearance than the old highways thru the larger cities.
    Michigan would be my concern.
    I have lowered my trailer ride height on some loads to make it legal height. Depends on where the load measures tall.
    Most states allow issue of permits 24/7, Easy and quick to set up. This load doesn't sound to much oversize and should be easy to get permits online.
    God prefers Diesels Thanks this.
  11. God prefers Diesels
    4,198
    22,259
    Jun 26, 2020
    South Texas
    It's the same height across the trailer. So highest in the center of the arch. I don't think I can get a permit, because the load is definitely divisible. If I'd caught it when I should have, it could have been fixed at the shipper.
