over dimensional loads
Discussion in 'Ask An Owner Operator' started by Marcush315, Nov 27, 2018.
  1. Marcush315
    Marcush315 Bobtail Member
    9
    Aug 25, 2018
    When it comes to hauling over-dimensional freight what is considered over sized as far as how far it can hang off from the end of the trailer or off the sides with a regular flatbed. im looking to do over sized with my company ive been driving regular flats for 1 yr.
  3. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Anything 103 inches and wider is considered over width. 102 inch wide trailer is 8'6. 8'7 is technically considered over width.
    EDIT:
    This excavator was 1 inch over on both sides. 104 inches over all. Yes it will require a permit for legal travel.
    Hurst
    Nothereoften and Marcush315 Thank this.
  4. Marcush315
    9
    Aug 25, 2018
    Thanks so would over length be 103 inches too? Another question how does going through tolls and weight stations with an oversized load work. I see signs that say oversized trucks park whats the reason for that?
  5. justa_driver
    justa_driver Road Train Member
    1,105
    817
    Apr 2, 2014
    Tennessee
    So they can check your permits/load to make sure you are legal
  6. Hurst
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    Over length and over width are two different things.
    Different states have different rules regarding over all legal length and how much front and rear over hang is allowed before permits are required.
    Typically 75 to 85ft over all length is common with no more than a 5ft over hang off the back.
    Trailer length must follow different guidelines as well. A 48' and 53' ft trailer can have different rules when it comes to rear over hang.
    Certain routes may restrict length to 45 - 60ft over all. Always check your atlas and follow your permitted route. Avoid going out of route or you can get cited. Some states can fine you for leaving the interstate and exiting to get fuel at a truck stop.
    103 inches would be for width,.. not length.
    When on a permit load,.. you typically never head for the scale unless directed to do so. You pull off and walk in with your permit and CAT scale ticket as well ad your cab card, insurance etc. Most of the time they just check to see that your permit is valid and tht you are on route. They can and will come out and check the dimensions of your load to see that your permit covers the load properly. It is easier to permit for max width (Permit for more than you need) than it is to have a load that is wider than your permit calls for.
    When ever on an over dimensional or over weight load. Never leave the shipper with out the proper permits. Big no no.
    Hurst
  7. MartinFromBC
    2,769
    12,476
    Oct 19, 2018
    If you are in Canada it changes from province to province. Half the places i would be considered oversize when running empty, because I pull a 10 foot wide trailer. Technically on most roads around me i can legally drive it because its properly lit. But a few roads it is illegal when empty. When equipment is wider than my trailer is, well then just start calling the scale shack and get the permits flowing in.
    I actually get less grief at the scales when i pull in 14' wide, 15' high, and at 190,000 lbs, than i do sometimes in say a fuel truck that was legal when i left but is now a few thousand pounds over due to snow load from the drive. I just pull the permits and go, no worries. But i have to say i still cringe some at every bridge i go under when i know its only about 4 inches or less higher than my load is, despite measuring it twice.
    Nothereoften Thanks this.
  8. jrhd97
    jrhd97 Light Load Member
    158
    578
    Oct 7, 2014
    NC
    What dimensions require permits varies greatly by state.
    You have single trip permits and blanket permits. A lot of states allow us to run 60 ft loads under a blanket permit while a few require single trip permits.
    The permits also vary by state for the same load. One will allow night travel while the next will not. One may not require escorts while the next state will.
    Read your permits very, very closely. I can't stress that enough.
    Driving for a company that already handles OD loads they should know ahead of time if you need permits and have them ordered. It makes life easier for you. Just make sure you have permits in hand before leaving the shipper and make sure ALL the info on the permits are acuraccu.
    Tug Toy Thanks this.
  9. mangdriver
    mangdriver Light Load Member
    61
    57
    Feb 13, 2016
    Most states 8'6 to 11'11" or 12' and under is just giving the se your money, and may restrict some roads. I know in mass any overhang longer than 4' requires a permit. And you don't need police escort until you reach 135' overall. We do oversize all the time watch your mirros, and your permits.
  10. Nothereoften
    Nothereoften Light Load Member
    261
    265
    Oct 6, 2018
    10 wide trailer in Alberta is a permit but everyone who has one has an annual permit. Anything over the edge of a legal width trailer is oversize. Rear overhang is 3'-5' depending on where you are
