Opinions on Pre-Purchase Truck Inspections
Discussion in 'Ask An Owner Operator' started by WrenchWrenchWrench, Jul 1, 2017.
  1. WrenchWrenchWrench
    WrenchWrenchWrench Light Load Member
    131
    118
    Jan 3, 2016
    Anybody ever use a independent 3rd party that goes to and inspects used trucks for you before you buy them? I've been thinking about doing this on the side in addition to side work when it comes up in the greater Houston area. Just not sure if anyone would be interested, or if its even a common thing. I think if nothing else it might add peace of mind to potential out of state buyers. Maybe give a bargaining chip to the buyer.
    I'm not talking about a quick speedco inspection, more like a very in-depth look into every system on the truck. Throw the A/C gauges on it. Hook a scan tool up to check out any codes. Check 5th wheel slack. Check clutch linkage play and adjustment. Check slack in pins and bushings. Point out quick fixes that were made. Note all the leaks, chaffed lines, loose bolts, missing brackets etc. All the little things that can cause havoc down the road. Something much more detailed than a regular PM inspection, and maybe make use of tools some guys don't have.
    Would anybody pay to have a Certified Mechanic go out and look over a truck like that before you bought it? If so whats it worth to you? If not why?
    Thanks!
    tarheelsfan105 and kimbosa Thank this.
  3. T-BoneX
    T-BoneX Light Load Member
    129
    50
    Jul 4, 2014
    South Bend, Indiana
    I plan on paying a 3rd party mechanic to check everything out after a DYNO is ran when I purchase myused truck down the line
  4. Tropsnart
    Tropsnart Road Train Member
    1,126
    2,377
    Jun 8, 2015
    Pavilion New York
    It'd be worth every penny if said inspection company actually did all of that. I'd figure about $250 to $300 would be worth it, maybe more.
  5. Tropsnart
    1,126
    2,377
    Jun 8, 2015
    Pavilion New York
    I'll add that in 16 years as an owner operator the largest problem I've found isn't finding good paying work, getting paid or anything that so many talk about on this forum. Rather I have had more trouble finding qualified trustworthy reliable competent mechanics to work on my truck. Dealerships, small independent shops, road service mechanics doesn't matter, finding good ones is very important.
  6. kimbosa
    kimbosa Medium Load Member
    524
    351
    Jul 4, 2011
    lufkin texas
    I think thats a great idea!
  7. WrenchWrenchWrench
    131
    118
    Jan 3, 2016
    Thanks for the input, I would like to put a detailed report together within 24 to 48 hours adter its done. Pictures and everything. Something similar to a home inspection you would have done before getting a mortgage.
    brian991219, Tropsnart and kimbosa Thank this.
  8. kimbosa
    524
    351
    Jul 4, 2011
    lufkin texas
    Im a ltl driver right now, but soon i see a truck and trl. In my future, houston is mostly like were i shop! So u might be getting a call.
  9. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    You should include having a Dyno, full ECM dump, and oil sample done with your inspection to be a true value to potential clients. If you do not have the resources to include those services you could probably contact with a local company that does.
    kimbosa Thanks this.
  10. T-BoneX
    129
    50
    Jul 4, 2014
    South Bend, Indiana
    If that's the case then you'd just be giving extra money for no reason. Take it to that said local dealer yourself then, right?
    Why pay someone money to take your truck to a local shop?
  11. Ubu
    1,252
    1,178
    Aug 25, 2012
    The OP is proposing a service to potential truck buyers, some of whom are not local, to inspect trucks before they buy. Offering those additional items would be giving those clients a full service instead of making them have to go do ithose additional checks that most want done themselves. He should be able to get a discount from anyone he contracts with to include those items and make it up to the same rates that they normally charge.
    They could be offered as optional additions to what he proposed doing in is post and for out of area clints would be of value.
    If I was looking at a truck out of my area I know that would be a service I would want over just one doing what the OP is proposing.
