Opinions on Great Dane flats?
Discussion in 'Flatbed Trucking Forum' started by 2CAN, Jan 24, 2014.
  1. 2CAN
    2CAN Medium Load Member
    613
    2,756
    Jan 7, 2010
    I'm looking at a 2009 Great Dane 48x102 steel frame, aluminum deck combo flat this weekend. I am curious if anybody here has one? I have not pulled this brand of flat before.
    How do they compare to East, Wilson or Fontaine?
    Thoughts?
  3. mc8541ss
    mc8541ss Road Train Member
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    I have an 06 and have had almost no problems. I purchased it in 08, it was only used for 9 mos before I got it. It still has most of the original lights. I have replaced 2 wheel seals and 1 bearing. I haul steel 90% of the time and a fair amount of that is coils. Good trailers in my opinion. I have not pulled an East or Wilson but they are very comparable to the Fontain. And head and shoulders above the transcrack trailers.
    2CAN Thanks this.
  4. Flightline
    Flightline Road Train Member
    2,345
    1,165
    Oct 1, 2011
    Almost There
    Normally quite a bit heavier than a Fountain.
    Mercer Transportation uses and sells great Danes. They went from Fountain to great danes because of the better warrenty approx. 10 years ago.
    I have a Fountain step and love it. Weighs in at 10,400
    2CAN Thanks this.
  5. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    I've got one of those mercer great danes. It is what it is man. A cheap study trailer that gets the job done. Just don't plan on winning any beauty contest. Like flightline said, it's a bit heavy. If you need to scale 50k, keep shopping. Also make sure it has the coil package, even if you don't ever hall coils, it really strengthens a trailer up.
    2CAN Thanks this.
  6. kachup
    kachup Medium Load Member
    312
    305
    Oct 23, 2013
    why do people bash on Transcraft ?? IMO they are great reliable trailer with a great Hendrickson suspension, Just Cheap Paint.
    Great Dane Freedom LT are awesome strong Trailer, And they look good, A bit Heavy but gets the Job Done. Make sure it has all 8 aluminum wheels.
    I compare them More to a dorsey , you dont see them much
    2CAN Thanks this.
  7. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    Better warranty than Extreme Beam lifetime warranty?
  8. fencitup
    fencitup Light Load Member
    225
    113
    Jan 12, 2014
    Bronx, NY
    Actually going to the dealer in the morning, well I guess its morning already to check out the Freedom XP by Great Dane
    From the website:
    [TABLE="class: droplinktable"]
    [TR]
    [TD]Weighing in at 8,200 lbs equipped with aluminum wheels, the Freedom XP is nearly 1,000 lbs less than a comparable combination steel/aluminum trailer. The Freedom XP maximizes payload capacity being able to withstand 60,000-lb loads concentrated in four feet and up to 120,000 lbs of uniform distributed loads.[/TD]
    [/TR]
    [TR]
    [TD] [/TD]
    [/TR]
    [/TABLE]
  9. Flightline
    2,345
    1,165
    Oct 1, 2011
    Almost There
    wow
    sounds impressive Lets see a picture
  10. fencitup
    225
    113
    Jan 12, 2014
    Bronx, NY
    Well Flightline... My trip to Great Dane was a waste of time. I think I just caught them at a bad time(right after lunch). I will leave it at that!
    But, the day was not a total waste. I did get to a Freightliner and Peterbilt dealer. Before I set out, I thought I knew what I wanted, and was just looking for confirmation. After returning home I have turned 180 degrees. Going to do a bit more homework and go back in a few weeks and get some solid numbers and go from there.
  11. mc8541ss
    1,467
    2,015
    Sep 22, 2007
    Lower Alabama
    Is that the all aluminum?
