One Size Fits All Tarps?
Discussion in 'Flatbed Trucking Forum' started by FREEBRD, Feb 22, 2010.
  1. FREEBRD
    FREEBRD Medium Load Member
    499
    116
    Oct 18, 2007
    Lafollette tn
    Went to pick up load of lumber, got loaded and tarped, forklift driver comes and says cant leave because some wood is showing, so i have too unload. Very frustrating!
    Apparently i needed 8ft drop lumber tarps and only had 6ft tarps.
    Said i was the third truck to have too unload because of wrong tarps!
    Is there a one size fits all? Seems like the weight keeps going up? so i cant keep carrying steel, lumber and smoke tarps.
    So, my question is will 8ft lumber tarps work for everything. I NEED TO BE ABLE TOO SCALE 48 THOUSAND#.
  3. krash13ss
    krash13ss Light Load Member
    173
    57
    Nov 12, 2008
    shady point ok.
    I got away with just lumber tarps for years.If buying new get extr row of d rings about 1 ft down from top that way they will work for steel plate.9 ft drops should cover everything.I have 10 ft for my step.Add a couple of 28x16ft when you can afford it-makes life much easier
    SHC Thanks this.
  4. FREEBRD
    499
    116
    Oct 18, 2007
    Lafollette tn
    Were are the best place to get them? also is there water proof canvas or such?
    So, what is the be spacing going for d-rings going up tarp? 8-4-2?
    freightliner438 Thanks this.
  5. shooter19802003
    5,654
    42,106
    Feb 8, 2010
    a 3 peice set of 8 foot drops will do anything you want. Just pay extra for a few more rows of d-rings. If you can afford them, go with the kevlar tarps. They are sooooo very nice, but pricey and a fraction of the weight of regular tarps.
    Edit: I like to have d-rings every 2 feet down the sides.
    rookietrucker Thanks this.
  6. krash13ss
    173
    57
    Nov 12, 2008
    shady point ok.
    The last set of lumber tarps I bought came from sharps tarps in grants pass Or.My steeltarps came from shur-co ft.dodge Ia.I believe there are a bunch of locations for shur-co.Spacing sounds about right with extra row at 1 ft.I used to get a discount at sharps because I was leased to combined transport.They were already made the way I wanted them.You can get them in different weights but the lighter they are the easier they are to tear.You should have a tarp shop in nashville-runs around 800-1000 dollars.Be sure to get patch kit and can of glue-big can.Keep rags,carpet old gloves, anything to protect from sharp edges.Oh yeah,big roll of duct tape.good luck
  7. shooter19802003
    5,654
    42,106
    Feb 8, 2010
  8. FREEBRD
    499
    116
    Oct 18, 2007
    Lafollette tn
    Thanks Kras! should just buy a van or reefer not enough money for all the Bs!:biggrin_25513:
    need omuch equipment and no place to put it !
  9. sandman1976
    sandman1976 Medium Load Member
    411
    47
    Mar 5, 2009
    burgaw,nc
    u can buy tarps # myteeproducts.com or another company advertised in the truck mag
  10. YETI1
    YETI1 Light Load Member
    182
    40
    Jan 1, 2008
    kansas
    tricity canvas:biggrin_25524: good products fair prices..
  11. rjmcgee
    rjmcgee Light Load Member
    121
    74
    Feb 23, 2008
    Klamath Falls, OR
    My last trailer had 5 or 6 foot drop tarps with extentions you could clip on to get to 8 foot. They were nice, I only had to use the extentions once, everything else was good with the shorter drop which makes tarping alot easier if you not trying to fold 4 feet of tarp up every time.
    Skunk_Truck_2590 Thanks this.
