onboard axle weight scales for air and rubber block suspension's
Discussion in 'Trucks [ Eighteen Wheelers ]' started by log trucker, Dec 15, 2013.
  1. log trucker
    log trucker Light Load Member
    161
    10
    Dec 19, 2011
    marshfield wi
    I'm wondering if they make axle weight scales for rubber block suspension and who makes it. I also am thinking about weight scale for pup trailer that is air ride with level valve on each axle. Also have a lift axle that is air and truck has springs on steer axle with air bag shocks. Its a log truck 4 axles on truck with 2 axles on the pup trailer. I could set up the pup trailer which would give me an idea of what's on the truck?? There has to be others out there who have set up something similar. So let's hear it. Thanks in advance.
  3. Rock hauler
    Rock hauler Light Load Member
    264
    54
    Nov 26, 2008
    Deridder La.
    They put load cells under the fifth wheel and sensors on the air bags. Vulcan is good I have SI on mine, most of the time there between 200 to 500 lbs
  4. log trucker
    161
    10
    Dec 19, 2011
    marshfield wi
    No fifth wheel. Straight truck with a loader and I pull a pup trailer.
  5. Rock hauler
    264
    54
    Nov 26, 2008
    Deridder La.
    they put on a center point maybe its the same
    log trucker Thanks this.
  6. grump
    grump Light Load Member
    74
    29
    Jan 1, 2011
    PA
    What suspension? I had them on one I have mixed thoughts they worked awesome on old style Hendrickson beams not fabricated ones ! I had the, on chalmers they were ok at best knew of a couple that was on air ride but could get it closer with regular air gauge than the on board system .
  7. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    I have pressure gauge on truck and trailer and I have a small chart kpa-to-kg
    so U can install air pressure gauges and "calibrate" on scales with small PSI to LBS chart
