On side of road with a code. Need help
Discussion in 'Freightliner Forum' started by irishluck09, Jun 18, 2021.
  1. irishluck09
    irishluck09 Light Load Member
    268
    133
    Nov 24, 2019
    2014 cascadia dd13
    I have a spn 2011 fmi 9 code.
    Abs light on
    Truck started to sputter on me.
    Now im on the side of the road.
    Thats the only code. Any idea what it is?
  3. Don379
    Don379 Heavy Load Member
    714
    1,286
    Jan 7, 2021
    SPN 2011/FMI 9 - GHG14
    J1939 Message is Missing from Source Address 11 (dec) . This code sets when there is a loss of communication from the ABS module
    J1939 message is missing from source address 11 (dec)
    DescriptionJ1939 Message is missing from source address 11 (dec)
    Monitored parameterCAN communication
    Typical enabling conditionsAlways enabled
    Monitor sequenceNone
    Execution frequencyAlways enabled
    Typical duration2 seconds
    Dash LampsNone
    Engine reactionNone
    VerificationIgnition cycle
    Check as follows:
    Show/Hide Checkboxes
    1. Check for multiple codes. Are there any SPN 168 (battery voltage) fault codes present?
      1. Yes; repair the battery voltage concern. Verify repair.
      2. No; Go to step 2.
    2. Is SPN 625/FMI 9 fault code present?
      1. Yes; repair the Controller Area Network (CAN) line. Verify repair.
      2. No; Go to step 3.
    3. Has the Common Powertrain Controller (CPC) been recently programmed? Check for proper configuration of the CPC against the server information. Does the CPC have the proper configuration?
      1. Yes; refer to the OEM diagnostics for troubleshooting the loss of communication to the ABS module.
      2. No; correct the information as necessary. Verify repair.
    Printed Wed Apr 01 2020 08:56:09 GMT-0400 (Eastern Daylight Time)
    baha Thanks this.
