On-guard system disable question.
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OTR48+C, May 18, 2018.
  1. OTR48+C
    OTR48+C Bobtail Member
    45
    10
    Dec 13, 2010
    I have a 2016 KW T680 that came with on guard system what is giving me a lot of trouble, this junk is off guaranty and every time that I take it to the KW dealer is a money pit, problem is that get the engine light on every so often and they need to re-adjust the radar of the on guard system, they willing to disable on guard but they told me they have to disable ABS and TC as well what I don't willing to do.
    Is anyone know if this is true that On guard is tie to ABS and TC?
    any suggestion will be appreciate.....
  3. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    Is it the one with the little rectangle box on the dash?
    I ask again lol
  4. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    I just unplugged mine the truck runs normally just have a check light on the dash
    AlexD13 Thanks this.
  5. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    If it is the one with the box on dash. Before turning the key to on hold in both buttons then turn key to on. It is now disabled.
    KB3MMX Thanks this.
  6. sdaniel
    sdaniel Road Train Member
    5,511
    4,420
    Sep 7, 2011
    Pelham N.C.
    Lose the cruise control , at least on the Freightliners.
  7. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    The way I disabled it, CC still worked on both Freightliner and on KW's
    AlexD13 and KB3MMX Thank this.
  8. OTR48+C
    45
    10
    Dec 13, 2010
    The real problem is if I unplug it... my engine light is on.
  9. OTR48+C
    45
    10
    Dec 13, 2010
    True but if unplug it engine light will be on and will not pass DOT inspection....!
  10. InTooDeep
    4,981
    37,363
    Jan 17, 2016
    Carmichael CA
    You don't have to unplug it. Just try key off hold both buttons in and turn key on
    KB3MMX Thanks this.
  11. Sharky88
    715
    851
    Sep 25, 2013
    Well I've had a dot and passed. It's a check light not a warning light. But hey you do you
    flood Thanks this.
