Found this on my pre-pre-trip for a 0-dark-30 delivery at Walmart in Pauls Valley in the am.
It is the main aluminum beam on a KW T-600 with AG-380. The end that the shock attaches to broke off. I had the tools on board to take the shock down so I can get around. Just not the bigger tools and jack to handle u-bolts and the spring shackle in the front. The break had some dirty spots, suggesting it had been cracked already and finally came all the way off.
Figured I'd throw this out for shop recommendations. My first choice would be either KW dealer in OKC or Ardmore, OK about the same distance either way from PV. Mainly on the premise they may have the part in stock or can get it. Conveniently, the part numbers are clearly available on the broken end LOL
If anyone has had some good suspension related work done in the area, please share. I'm not stuck on going to the dealer, but I also don't want to grow old while someone screws around getting parts. Unless someone posts a go-to place, I'll probably call the two dealers' parts counter to see if they have it, then transfer to service to find out if they can get it done fast.
Thanks in advance!
OKC - Ardmore, OK suspension shop?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by RedForeman, May 19, 2013.
