you know signs like these...
No trucks...
but what if you're a bobtail truck? are you allowed?
same can even go as far as a garbage truck, hey it's a "truck" right?
Why can't they just make it simple and say no tractor trailers if thats what it means!?!![]()
okay I have a dumb question about "no trucks" signs
Discussion in 'Questions From New Drivers' started by freightwipper, Nov 10, 2014.
Page 1 of 3
Usually that means no trucks as a thru route.
Local deliveries are normally exempt. But not always.
I think that sign has as many different meanings as places it's posted.passport220 Thanks this. -
now I'm even more confused!
darn! lol
I take that to mean no commercial vehicles, even an F250 with commercial plates.
Edit... I just realized it depicts an actual tractor trailer. In New York, I've only seen that sign with straight trucks. -
If I was driving bobtail and encountered that sign I would obey it as though attached to a trailer. Too much ambiguity and what LEO says goes. And if he thinks otherwise it is going in the ticket book and you are going to court. But that's just what I would do. Others may have different opinions.
Edited to add... A truck without a trailer is still a truck.GenericUserName Thanks this. -
That sign is very specific.
It means no black single axle daycab cabovers with a red stripe across them.
All others are fine.amiller, joseph1135, surfernabox and 21 others Thank this. -
surfernabox and blairandgretchen Thank this.
They typically list either an empty weight or GVW along with the sign. It might say, "No trucks over 7,000 lbs. empty weight" or whatever... this, of course, applies to commercial vehicles using the route as a through route.. local deliveries are exempt in most cases, as are RVs.
I remember seeing plenty which list a max GVW of 10,000 lbs., meaning a pickup like an F250/Silverado 2500/Ram 2500 would be too heavy to legally be on that road, although it naturally doesn't apply to the same vehicle when it doesn't have commercial plates.
In the instances where they list a max GVW, keep in mind they're talking about the actual weight rating of the vehicle, not the actual weight at that time. So your bobtail might weigh 17,000 empty, but it'll have a GVW of 52,000 - 54,000. -
I believe it would be situational.
Depends on where the sign is.
Page 1 of 3
