Ok, dumb question...fixed spread...Cali freight...bridge rule
Discussion in 'Flatbed Trucking Forum' started by the_3_bears, Nov 6, 2019.
  1. the_3_bears
    the_3_bears Bobtail Member
    19
    14
    Oct 31, 2019
    Ok, been driving four year. 2 Dry/6mo refer/1.5 flat. All of our trailers have sliding bogies. I just keep them full forward, watch the air gauge when I get loaded and never have to...ok that’s a lie, rarely have to move them.
    I know the rule either way you want to state it. I’m looking at buying a step deck. The better priced ones I’m finding have a fixed spread. However, when I count the stripes from the rear of the 53’ end, it looks like they are only six feet back...the tool box is where the 40’ mark would be. I see guys pulling these in Cali...I don’t think they are legal, or is there some rule I don’t know about, like how to beat the “house” in Vegas.
    thanks for any input....
  3. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    In Cali
    The 53 is legal as long as the back axle is slid to the front axle. Closed axle. PITA when loading at a lot of places. And most don't have a scale. If you're seeing a 53 spread. I have no idea how they're rolling around that way.
    If you notice Melton flats. Their spread is positioned more forward to meet Cali KP. I think it's Melton anyways.
    I would think they'd have a hard time with gross weight with that shorter bridge.
    48's are legal with a spread. For most of the country.
    IIRC. There's 11 or 13 states that require 53's to have closed axles. I don't have that list anymore of closed axle states.
    53's aren't worth having unless you know for sure you're going to be using that extra 5 feet quite often. Most loads fit just fine on 48.
    One thing you'll also want are 35 foot straps. For those contains that sit on the top deck but are too long. 30 isn't long enough to strap the back of the container which will be hanging off the rear. Supported by dunnage.
    Bean Jr. and x1Heavy Thank this.
  4. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    A trailer over 48' is measured from the kingpin to the center of the rear axle. You'll have to be 40' or under. That means sliding the rear axle up or having a trailer with the kingpin further back.
    x1Heavy Thanks this.
  5. Espressolane
    16,994
    102,530
    In California, and few other states, you will need to meet bridge laws. 48ft trailers are exempted from this.
    Could be a flat, step or even a box, as long as the max length is 48ft and it’s a 10’ spread.
    The 53’s should have one of two basic options.
    1 a California fixed spread. The axles will be set at the king pin to last axle center to meet bridge law. These will have at least 8 feet of overhang from the last axle center to the end of the trailer. Have seen more, the king pin set has a lot to do with that.
    2 slide or adjustable axles. Usually have a long spread position, usually the front axle is about 39ft KP to center. The rear axle can be moved up to make a California legal tandem. Max load weight will drop to 34k on the tandem. Most people will say something like axels open or closed, sometimes use spread for open.
    The 53’s you see running California in the open position, or a long spread, They are not running within the bridge law requirement. They can be cited for that. Does that stop any one from doing that? Well you have seen it. Does rolling across a scale get you stopped for it? Sometimes. When the scale is busy, lots of trucks backed up, chances are, no. Then if the rear axle is a lift, empty or light(under 20k) the axle could be up and be legal.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    A 48 foot spread axle flatbed is more than adequate for much of the USA. Ive run one for a time and it's way better than dealing with a 53 anyway.
    Bean Jr. and ChevyCam Thank this.
  7. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    Just depends on the freight you haul, it would be nice to be able to buy one trailer and be able to bridge maximun loads in all 49 states and canada. But it will never happen. lol
  8. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    that's true.
    I hate to pick on California so much, they don't get to constantly wag the National Dog with their state laws that somehow get adopted by the rest of the USA> Ugh....
    I have been in cali too much. It's fine by me that I don't worry about them anymore. I wish them well, no hard feelings. But sheesh.
  9. Long FLD
    Long FLD Road Train Member
    11,378
    45,908
    Mar 4, 2015
    First, it’s not a bridge law it’s a king pin to rear axle law (KPRA). Bridge laws deal with weight. But as mentioned, to be legal in CA any trailer over 48ft has to meet their KPRA law be it either by sliding the rear axle forward or having the spread assembly fixed forward enough to meet the requirement.
    Bean Jr., Rugerfan, kylefitzy and 2 others Thank this.
  10. the_3_bears
    19
    14
    Oct 31, 2019
    Thank you. I thought that was the exact law as posted by espressolane. I just started my 10 at Loves in Cochella went to take a shower and sure enough, there is a 51 footer here axles all the way back, in violation of Cali law, guess he is willing to risk it (of course if he has a permit, which I doubt). So, my search continues. I really want a 53 step because of the loads I’m getting offered.
    Espressolane, Long FLD and x1Heavy Thank this.
  11. Long FLD
    11,378
    45,908
    Mar 4, 2015
    I ran out there for almost two years with a 52ft spread cattle trailer before I got measured. And I was out there at least once, sometimes twice a week. Just depends on how much you’re willing to risk it.
    Rugerfan and Oxbow Thank this.
  12. Espressolane
    16,994
    102,530
    Before you fully commit to the 53, consider what you really want to do with it and why.
    I think if you look at what is on the deck for most of these, your looking at a lot of wasted space. True that some freight, it is advantageous for a 53.
    When I was running a 53 step, the last 6 to 8 feet were empty 97 percent of the time. Primarily due to weight, and load balance.
    Bean Jr. Thanks this.
