Hello all...in your not away I have a 2016 kw paccar mx13. They use Delo 10w30 from factory..manual says can use 5w30 in winter as long as its approved oil rating. CJ-4. I believe..anyways I'm a full believer in full synthetic oils..not blended. However delo is a decent price. But I cant find true numbers on the protection it offers...many other oils have info somewhere on the protection levels. Aka. Zinc..phosphate etc. I was looking at amsoil..crazy expensive however good numbers and overall great oil..they offer a 10w30 but I believe I want 15w40 in summer and 5w30 in winter..however the "research" Chevron has done says converting to 10w30 saves fuel. Roughly 1 percent to 2 percent. Hints why they are used from manufacture now. Any thoughts or opinions? Oil is a big debate I know but this truck has miles on her and will have many more..close to 900 in 3 years or so I'm guessing..so protection is on my mind heavily..however amsoil is roughly 300 dollar difference in price
Oil topic..cheaper oil vs expensive oil
Discussion in 'Ask An Owner Operator' started by vr4dad66, Nov 21, 2019.
Page 1 of 3
I use Schaeffers in my OTR truck, and it’s about $22-$23 a gallon, which is about $10 more than the Rotella that I use in my local trucks.
blacklabel and FlaSwampRat Thank this. -
Rotella-T. Listen to this, one job I had, the boss used nothing but Rotella. I was out and needed a gallon of oil, they didn't have Rotella so I put in Delo. I figured better that than low. When I got back, I told the boss, he said bring it in the shop and they changed the oil.
FlaSwampRat and Farmerbob1 Thank this. -
I would say synthetic oils shine in the cold temp start up. They can flow faster when cold and still give you the same protection when engine is hot like 5w-40
They also cost more so. You can become a Dealer for Amsoil and get cheaper and never actually sell any oil. I did that it simple online and $35 or something. I ran Amsoil when I had my own truck then Rotella had their synthetic oil. You can get that at Walmart for like $20 a gallon. Nobody has been able to prove if different brands are really any difference.. not sure if Rotella has 5w-30 oil yet in syntheticFlaSwampRat Thanks this. -
If it meets mfg requirements, run it.
FlaSwampRat, Roger McG, Bean Jr. and 1 other person Thank this. -
FlaSwampRat and Brandt Thank this.
I have done oil analysis for years on my trucks.
I used Co-op brand 0W40 synthetic in my last truck. Oil analysis was always fine. Truck was at dealer one time , had them do oil change, they used Shell Rotella T6 synthetic. The following oil change I put back in the Co-op. But when I got the analysis results of the Shell, all of my metal wear numbers were half of the Co-op numbers.
So after that I switched over to the Shell and the analysis numbers settled in about one third of the Co-op numbers.
The Co-op numbers were always fine, within spec. But the Shell numbers were much better. I translated that to mean longer wear life for my engines.blacklabel, mp4694330, FlaSwampRat and 3 others Thank this. -
I'm no expert on this subject and don't pretend to be. There are many threads written about oil and oil additives out there. One that got my attention was wrote by Rawze.com about Lucas oil additives and his views on using it. Up here in Canada, the emphasis is on cold starts in -30c weather. If you research the subject, it's scary to imagine the damage caused by cold starting. Most trucks won't even start in this weather without using ether or some type of starting fluid. This has led to drivers idling trucks all night and with DPF/DOC issues, carbon/sludge/varnish build-up and premature engine damage. Using engine/bunk heaters tend to drain batteries quite severely and risk losing cranking amps to turn over engine. Some have equipped their trucks with APU units which has worked with excellent results saving fuel and idle damage.
Trucks up here tend to switch to a thinner oil during winter, then back to 15W-40 in summer. As long as the oil meets manufacturer's requirements both summer/winter (warranty), regular drain intervals and oil samples, I think we tend to fall victim to "miracle cures" for our engines.FlaSwampRat and AModelCat Thank this. -
15W-40 typically covers 50C to -9.5C
0W-40 typically covers 40C to -40CFlaSwampRat, pushbroom and Johny41 Thank this. -
FlaSwampRat, PE_T, Bean Jr. and 1 other person Thank this.
Page 1 of 3
