Oil temperature
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JORTRUCK, Jun 11, 2017.
  1. JORTRUCK
    JORTRUCK Light Load Member
    232
    31
    Mar 9, 2017
    Screenshot_2017-06-11-01-30-30.png Oil temperature reached almost 300
    After 40 mints driving around 55 mph hour flat road no load no hot weather
    Oil pressure was around 60 . engine was around 180 . And I checked the antifreeze was almost full whole the way up
    So the only makes me worry
    Oil temperature around 300. So whats wrong with that ? No engine check light comes on the dashboard
    tinytim and Oxbow Thank this.
  3. Grouch
    Grouch Road Train Member
    2,140
    4,451
    Feb 3, 2009
    Between here and eternity
    First thing I would check is the sensor and then the dash board gauge.
    Oxbow Thanks this.
  4. JORTRUCK
    232
    31
    Mar 9, 2017
    What else can be you think ? I'm worry may be engine problem or big issues or something like this
    Oxbow Thanks this.
  5. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    What engine and Year? Might be oil cooler is Plugged.
    Oxbow Thanks this.
  6. Strange77
    Strange77 Light Load Member
    59
    36
    Oct 1, 2011
    I agree, if there's an ECM hook up and see if there's fault codes at that temp there should be. The only engine generally have 2 temp sensors 1 for ECM 1 for gauge. Sensor for gauge could be bad if ECM shows no problem.
    Oxbow Thanks this.
  7. JORTRUCK
    232
    31
    Mar 9, 2017
    DD15 Detroit 2015 . The other gauges oil pressure and water gauge was normal
    Only oil temperature and no check engine light why no come on when the oil temperature go up ? What the bigger issues can make the oil temperature go's up
    For example if Sensors I will be happy just need change it and that's it . But it's can be something else seriously like engine issues or something els can cost a lot money to fix
    Oxbow Thanks this.
  8. Strange77
    59
    36
    Oct 1, 2011
    I'll admit Detroit is not my field but Troubleshooting 101 is the same across all platforms. First thing first rule out the simple things I.E sensors. I'm still not convinced that there is a "Physical" (meaning actual problem) because if oil temp reached 300F bells, whistles, and the voice of God should have all been going off in your cab as well as a FC. Some sort of FC should have logged around the 250F mark. The only reason gauges exist is because people generally Americans are always on a Need To Know Basis. In the auto industry you rarely even see temp gauges. Either buy a cheap temp gauge from NAPA and find a port on the oil rifle to plug in to, or buy a cheap scanner that'll allow you to monitor temps that the ECM see's before jumping in the "this has got to be the end of the world" issue. I'd be willing to bet there is 2 temp sensors, 1 for ECM and 1 for dash gauge.
    Oxbow Thanks this.
  9. AModelCat
    166,503
    As a blanket rule, at 250F or above you are cooking the oil and the component itself. This goes for everything. Engine, trans, diffs, hydraulics, etc. Hopefully its just a failed sensor or wire. If the oil is really hitting 300F and you haven't bought the truck yet, run away very fast. More problems will be on the horizon.
    Oxbow and Strange77 Thank this.
  10. little cat 500
    2,061
    1,109
    Jan 17, 2010
    Abbottstown PA
    my freightliner has two sensors 1 to gauge 1 to ecm no way the ecm is going to let it run at 300 very long
  11. Ezrider_48501
    3,844
    5,135
    Apr 2, 2011
    bismarck, nd
    i would say failed sensor or wire as well, get a lazer thermo and shoot it at the oil filters and the pan and see what you get for comparison.
