Oil temp too high?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Msford, May 15, 2017.
  1. Msford
    Msford Bobtail Member
    13
    8
    May 15, 2017
    I have a 2001 6NZ CAT set at 550. My oil temp stays at 200 unless I get into a hard pull. It will rise as high as 215 to 220. My water temp rus about 185. Engine runs strong, 6.2 mpg and no complaints. I'm told it's running to hot, and I should change my oil cooler. I change the oil every 12000 miles with Shell Rotella, and Lucas. Anybody have any insight, or history with this engine temp? Any help would be appreciated.
  3. KeithT1967
    KeithT1967 Road Train Member
    1,458
    1,542
    Nov 12, 2008
    Springfield, Ohio
    Low 200's is normal oil temp range. Engine oil actually MUST get over 212ish otherwise it builds up too must moisture from condensation. The more humid the climate the more important it is.
    Bean Jr. Thanks this.
  4. Roberts450
    Roberts450 Road Train Member
    2,237
    3,635
    Feb 6, 2016
    Those temps are fine on a hard pull. Hell my ISX runs 210-220 just normally and Ive seen almost 250 on a LONG HARD pull in the summer with outside temps pushing 100.
  5. Msford
    13
    8
    May 15, 2017
    I appreciate the feedback. I was just concerned, because I have two friends with the same engine, but their oil temp are running in the 165 to 175 range. I did a little research, and found the newer engines run at higher temps, but wasn't sure if mine fell into the category of newer.
  6. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I used to drive a company truck with a 6nz. It's oil temp always ran around 180-190. Big pull 220-230.
    Now I have a newer truck with 2015 isx. Flat roads oil is 220 or so, big pull 235-240.
  7. Msford
    13
    8
    May 15, 2017
    I sure appreciate your help. I definitely feel a little more at ease.
    S M D Thanks this.
  8. Yourawahoo
    Yourawahoo Light Load Member
    84
    28
    May 8, 2017
    The hotter it gets the better it will run. To a point.
    Big_D409 and FlaSwampRat Thank this.
  9. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Yep but trying to figure out that point is the tricky spot. I always get nervous when it tops 220. But i honestly don't know where the point is that i need to back out of it. And talking to guys at detroit netted a bunch of "i don't know" answers.
  10. Diesel Dave
    8,520
    23,433
    Jan 20, 2010
    Hesperia, Ca.
    Dump the Lucas. Just keep your intervals in check.
  11. Msford
    13
    8
    May 15, 2017
    I keep it pretty tight to 12000. This engine is like clockwork. It takes a gallon of oil between oil changes every time around 2500 miles before service. You're not a fan of Lucas?
