Oil temp running high.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by SpankingGT, Feb 5, 2012.
  1. SpankingGT
    SpankingGT Light Load Member
    253
    55
    Sep 9, 2010
    14l Det- 2004 freightskaher columbia.
    I was told (dont know if this correct) that water temp and oil temp should be the same.
    Under a load- usually 42-45k- even with cold weather conditions, my oil temp is right around 200F maybe 5 under. I had the radiator replaced about a year back and had new thermosats put in as well. What could be done to lower the temp? I was told the temp should be around 185 or so.
    What could be wrong? Turbo and EGR cooler were also replaced last year.
    Thank You
  3. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    In my 12.7, my oil temp is usually always 5 degrees more than coolant temp, and always has been for the 6 years I've had this truck. It stays about 200 unless pulling a steep grade.
  4. thehammer69
    thehammer69 Light Load Member
    53
    15
    Oct 31, 2008
    Goose Creek, SC
    There is nothing wrong with your oil temperature.
  5. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    +1, oil temp is always hotter than coolant. 200-210 degrees or so, normal.
    Ezrider_48501 Thanks this.
  6. bob1234
    bob1234 Light Load Member
    71
    Nov 10, 2010
    brantford, ont
    On my 06 cat acert it runs 205 15deg more than my coolant
  7. Guardian
    Guardian Bobtail Member
    28
    5
    Jan 27, 2012
    Like they said, anything around 200° is normal, when the engine is working! And also you don't won't oil temp to run to low either, then it won't boil off moisture and condensation that forms in the crank case from the temp changes.
  8. SpankingGT
    253
    55
    Sep 9, 2010
    Thank you for your replies. I was told I was being paranoid and you guys confirmed that. Heh- thank you for your help.
  9. nakoBilly
    nakoBilly Bobtail Member
    21
    10
    May 20, 2010
    Norwalk CA
    My cummins isx normal temp when cruising 220 and coolant 185
    I wouldn't worry
  10. rollin coal
    rollin coal Road Train Member
    13,083
    25,871
    Mar 29, 2008
    TN
    My Cat must be weird. Oil and water temp are about the same. Actually oil temp always runs at 175* on the gauge while the water temp shows from 188* to 192* on CAT information display. I imagine the real oil temp is right with the water temp. On a hot day oil can go as high as 200* and on cold days it will drop down to 150*, and start consumining oil as well down that low.. 200-215* oil temp sounds normal for egr engines in general...
