Oil pressure gauge in dash not reading any oil pressure
Discussion in 'Freightliner Forum' started by Roanokemassey, Aug 21, 2023.
  1. Roanokemassey
    Roanokemassey Bobtail Member
    14
    5
    Jan 29, 2022
    2004 Columbia Glider with 12.7 Detroit.
    Oil pressure gauge in the dash is not showing any pressure.
    Other dash gauges are working. Installed a manual test guage and the engine has very good oil pressure.
    Truck runs so I know the ecm is getting a good signal.
    How and wear does the dash oil gauge get is signal. I look at the ecm diagram and I don't see any interface to the dash gauges.
    Appreciate knowing how the oil pressure gauge gets a signal.
  3. Hammer166
    7,350
    26,445
    Aug 18, 2007
    ~8600+' and loving it!
    I don't remember when the CANbus gauges started... Look at the back of the gauges, are they daisy-chained with a 2 wire plug (the lights are separate plug)? If so the gauge pulls it's signal off the bus. Prior systems the sending unit drove the gauge directly.
  4. Roanokemassey
    14
    5
    Jan 29, 2022
    Thanks, this one is a cluster, no separate gauge.
    I need to see if I can buy just the electric motor for the oil pressure.
    Thanks again
