Oil or grease brake drum
Discussion in 'Questions From New Drivers' started by Aradrox, Mar 9, 2017.
  1. Aradrox
    Aradrox Heavy Load Member
    900
    622
    Jan 21, 2016
    So had a hub oil seal brake and get oil all over the brake drum.. they won't replace the drum just cleaned it...But not even that well IMO... The way I am reading the regulations is there only has to be evidence of contamination by oil or grease on friction surface of drum or friction material the shoes were replaced. There was still enough oil or great that I can feel it and there is enough to show on figer that it was still present.
    http://imgur.com/a/AZlwG
  3. Loose Leaf
    Loose Leaf Medium Load Member
    311
    237
    Feb 2, 2017
    You done left the shop? Get some brake cleaner and clean as much as you can or take it back to the shop and tell them to do it right.
    buddyd157 and noluck Thank this.
  4. Aradrox
    900
    622
    Jan 21, 2016
    They are redoing it told them I refused to drive it like that.
    buddyd157 and Loose Leaf Thank this.
  5. Loose Leaf
    311
    237
    Feb 2, 2017
    They should have to pay you for lost down time and take it out of the mechanics pay and maybe the next break job will be do right?
  6. Aradrox
    900
    622
    Jan 21, 2016
    I get 75 a day breakdown pay
  7. DougA
    DougA Road Train Member
    1,429
    8,892
    Dec 16, 2013
    Retired,In my shop in Md.
    Drums will clean fine,no reason to replace them for an oil seal leaking.
    Grubby, MJ1657 and Toomanybikes Thank this.
  8. AModelCat
    154,481
    Honestly I'd have just sprayed a little degreaser and washed it off in the washbay. Willing to bet that is all the shop is going to do.
    PhilKenSebben, Chinatown and Lepton1 Thank this.
  9. mitrucker
    mitrucker Road Train Member
    5,140
    8,804
    Dec 15, 2010
    Lapeer, MI
    Clean the drum, replace the shoes, along with the leaking seal and any other necessary gaskets. Top off the fluid and ship it on down the road.
    Grubby, buddyd157 and Lepton1 Thank this.
  10. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    I had some grease come out of the cam bearing on the shoe end and grease has gotten on the shoe. What's the "evidence" mentioned above about? Will DOT make me replace the shoes even though I've removed everything from the drum and cleaned it up?
  11. Chinatown
    Chinatown Road Train Member
    73,281
    164,683
    Aug 28, 2011
    Henderson, NV & Orient
    Post #7 is all I've ever seen mechanics do.
    Grubby, Lepton1 and JimmyWells Thank this.
