Oil Leaking From Exhaust Manifold
Discussion in 'Trucks [ Eighteen Wheelers ]' started by JimmyWells, Aug 22, 2017.
  1. JimmyWells
    JimmyWells Road Train Member
    1,000
    1,078
    Apr 7, 2016
    One of the slip joints on the exhaust manifold (3406e) has oil dripping from it. Is this turbo giving out or have I just found my elusive leak and it's just soot?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,294
    Apr 9, 2009
    Humboldt, Sk
    I had a truck that did that, in my case it was soot and the coolant from leaking head gasket was flushing it out.
    Wound up doing an inframe.
    JimmyWells Thanks this.
  4. bowhunter67
    bowhunter67 Light Load Member
    283
    549
    May 28, 2016
    rush city mn
    what motor do you have because on isx it was valve seats that were leaking.
  5. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Sorry, forgot that important detail. It's a 3406e CAT. I can't tell if it's oil or soot/fuel.
  6. bowhunter67
    283
    549
    May 28, 2016
    rush city mn
    if you idle a lot it might be slobering unburnt fuel also mixing with soot making it look like oil.
    Star Rider, uncleal13 and JimmyWells Thank this.
  7. cnsper
    cnsper Road Train Member
    5,869
    27,421
    Feb 28, 2014
    Wipe some off and smell it
  8. Roberts450
    Roberts450 Road Train Member
    2,237
    3,636
    Feb 6, 2016
    Or taste it.
    Cabinover101 and JimmyWells Thank this.
  9. Roberts450
    2,237
    3,636
    Feb 6, 2016
    When I worked at NC Power systems in Seattle we had a 1000kw gen that was run with a 1500hp 3412. Had compound turbo's on each bank so 4 total. Started it up one cold winter day as the truck driver hooked up to it to haul it off. It was in a 40' container. Well it didnt have an idle mode, just start and full tilt boogie to 1800rpm but it did have a cold mode. So it was running and smoking white to beat hell and it went into cold mode dropping cylinders so that it could warm up faster. Well one turbo was in the center of the head and the other was at the rear of the engine over the flywheel housing. Well in cats engineering wisdom they just used a very light press fit exh joint from the low pressure turbo on the head to the high pressure turbo on the flywheel housing. Well when you got 1500hp worth of fuel in a 50 degree engine it dosent all burn. Then it leaks out of that joint and when the driver see's it through the open door he got a little freaked and ran off but I just laughed. Lol
    magoo68 and JimmyWells Thank this.
  10. JimmyWells
    1,000
    1,078
    Apr 7, 2016
    Yeah, they weren't think too clearly when they designed these exhaust manifolds that's for sure! So how can I stop it from slobbering after long idle periods? I already bump the RPM up to 950-1000.
  11. Rame
    Rame Bobtail Member
    17
    Jun 13, 2019
    Hey jimmy I have isx 550 year 2000 has leak as well. Can you please give me some advice. Please. I am uploading pic too 20190728_181825.jpg 20190728_181825.jpg 20190728_181825.jpg 20190728_181825.jpg
