Oil leak on exhaust manifold
Discussion in 'Trucks [ Eighteen Wheelers ]' started by brenes-built, Jan 14, 2012.
  1. brenes-built
    brenes-built Light Load Member
    157
    15
    Apr 14, 2011
    Vancouver, Wa
    Truck came in for oil leak. The inside of turbo was coated in oil looks like for some time, and after pulling turbo off manifold was leaking at the joint between #2 . After pulling off manifold #2 is wet from oil.. Any thoughts on why? Bad rings? Liners? It's on a detroit diesel..thanks
  3. Prom Night Dumpster Baby
    Prom Night Dumpster Baby Medium Load Member
    646
    473
    Jan 12, 2012
    Bug Tussle, TN
    Probably has a lot of blow-by huh? I mean even for a DD!
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Need to pull of exhaust manifold and c which cylinder oil is coming from could be valve guide or seals it a broken ring also check to make sure blow bye tubes not plugged or kinked
