OIL leak at water pump.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by heavyhaulerss, Jun 9, 2014.
  1. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Among the many small oil leaks on my ser 60 one bigger leak is where the water pump bolts to the front cover. I watched it drip out where the bottom bolt is, just a few inched from the weep hole. I had paid to have water pump resealed, the shop said they doubt it would do any good. we expected to find a pinched -o- ring, but shop could see nothing wrong, but put a new on in anyway. what else could cause this leak? when the engine is hot & oil is thinner it leaks more, it is blowing all under the truck looking a lot worse than it is.
  3. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Oil can track in funny paths. Could be coming from somewhere else. Try to give it a good steam clean and see if you can find the source.
  4. passingthru69
    Like the other poster stated, Steam it real good and then get some tracer dye. Most motor shops will have it.
    Then run the engine and look and see where the dye ends at and back trace it.
    Good luck and hope nothing major
    heavyhaulerss Thanks this.
  5. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    Dye is your best bet. The front of the head gasket has the oil feed & return in it, the front cover itself can leak (or be cracked). The front of the valve cover can leak and run down the front of the head. It's very hard to see between the front cover and the head, so dye or a bore scope is usually needed.
    I had an FLD120 once that was leaking out if the diamond seal on the left side, but was running between the head and front cover and leaking more on the right side behind the water pump.
  6. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    well I laid on the ground under truck & after spraying clean with carb cleaner, after about 30 seconds I see the oil seep from where the bolt goes from water pump to front cover. can see clear oil is not coming from behind water pump or any other location. it is from where the pump meets cover.
  7. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    If you are sure that it's where the pump bolts on and the seal is good, then I'd say that you have a problem with the cover, it could be cracked. I have seen them crack between the water pump hole and mounting bolt hole. They should have looked really close at that when they found that the seal looked fine though. Unfortunately, I'd say that the water pump needs to come back off to see what's going on.
    A slim chance, but worth a shot, the oil could be coming through the bolt hole. You could try taking out the bolt, clean the hole good with brake cleaner and blow it dry and try putting some RTV on the bolt. That may work, but it may not. Normally, there should be no oil in the water pump bolt holes, but if you have a crack in there, it's possible. I've seen 1 crack on the top inner bolt hole because someone pull a bolt in that was too long and forced it tight. It had a similar leak to what you describe, but more from the top inside of the water pump. I put some silicone on the correct length bolt and it's been going for almost a year now without leaks.
  8. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    well I tried the silicone & replaced the bolt, hope this helps. also noticed some oil coming from oil pan where 1 of the oil pan bolts are. do these bolts ever need replacing? what about the rubber isolators, I think they are called, or the oil pan itself? does it ever warp, or need replacing after 15 years & 1.6 mil miles?
  9. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I have seen many pans crack, usually around the metal inserts for the plugs. The bolts/isolators are sold as a unit, you need 10. I'd get a pan gasket and bolts, it's not a hard job. When you pull it, you can clean it up and check for cracks. Most dealers stock oil pans (aourd here anyway), if not, they can usually get them quickly.
    If it's not leaking too bad, I'd wait until next oil change.
  10. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    right , thanks.
  11. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    Hey the silicone tip seems to be working. pulled the bolt out, sprayed brake clean, a lot thru bolt hole . blew dry & let air dry in the hot heat for about 3 hours. put 3 thick flat washers on the bolt in case the bolt was too long & not pulling tight. put high temp silicone all over bolt & after tightening I put silicone between the pump & front cover exactly where the oil was dripping from. I remember seeing on e-bay a used oil pan for like $750.00 that is too much to take a chance on. will call my freightliner dealer & get a price on a new one in case I need one. thanks for your help.
