Ok, this may have been discussed somewhere else on the forum, however I just wanted to know from those experienced on trailer oil bath vs grease hubs on trailer axles. Personally,I like grease hubs because of lower likelihood of them losing oil,catching fire and having to find a shop to replace the axle seals and potentially brake shoes when oil hubs leak. Oil bath hubs on trailer axles work great, however you have to stay on top of them especially if you run mountain grades a lot,have to hop curbs slowly or drive the trailer axles on a serious grade while loaded pinching the axle seal. What say you???
Oil Hubs VS Grease Hubs on trailer
Discussion in 'Flatbed Trucking Forum' started by Otr Traveler, Apr 13, 2024.
Page 1 of 3
I thought all semi hubs were oil bath.
Only grease hubs I’ve ever seen is in light duty trailer applications. -
I don't know why anyone would ever choose oil hubs over grease hubs. I've never seen a grease hub that seeped, but plenty of oil hubs do.
Rideandrepair, Feedman, Tug Toy and 2 others Thank this. -
I'd much rather deal with oil bath bearings than grease. #### cleaning out and repacking that ####. Set the bearings, fill the hub and boot it out the door.
NightWind, jamespmack, cke and 6 others Thank this. -
cke, Rideandrepair, RockinChair and 3 others Thank this.
If you're pulling your own trailer, grease is the way to go. You have multiple O/O's/company trucks dropping and hooking, oil is better. At least they will sometimes notice the oil on the wheel/ground.
Rideandrepair, Feedman, Otr Traveler and 1 other person Thank this. -
Grease hubs if the trailers sit for long periods of time. If you’ve ever pulled apart hubs and noticed the top part of the bearings and races are corroded or discolored you’d know why. The oil settles to bottom and leaves the top side of hub and bearing exposed to moisture and rust will form pitting the polished surfaces. Grease will not.
You can still do grease steer axle hubs.gentleroger, Rideandrepair, RockinChair and 2 others Thank this. -
Latest truck I just ordered has grease hubs on the front steering axle. That was unexpected. I suspect everything is going to grease. All the trailers I have bought new in the last 5 years have been grease, just my older trailers that are oil and my 2019 truck has oil on steer axle.
Rideandrepair, Feedman and Tug Toy Thank this. -
You won't find grease hubs in the far north. At 40 below it's like glue if they are parked for longer than a few hours. Loaded, you're stuck. Empty...you're dragging tires if you can get rolling.
NightWind, old iron, Rideandrepair and 6 others Thank this. -
As a preventative measure I like to try to regrease the trailer axles hubs yearly...oil hubs on trailer axles you have to watch frequently..and if you have a leak you're toast. You have to find the nearest shop to replace the seal, bearings,etc.depending on any damage done.. I heard a guy trash talk grease hubs on trailer axles and now realize he probably didn't know maintenance records on his trailer..most trailer maintenance personnel only fix what's broken especially when it's a lease trailer..
Rideandrepair and BoxCarKidd Thank this.
Page 1 of 3
