This is a 13 speed transmission. Have oil leaking out of the shifter itself. Any ideas?
Oil coming out of gear shifter
Discussion in 'Questions From New Drivers' started by D.Tibbitt, Jul 14, 2021.
Page 1 of 4
Rideandrepair, DeereRunner97, JonJon78 and 2 others Thank this.
Air compressor is getting wore out and pushing oil into the system.
Rideandrepair, DeereRunner97, JonJon78 and 1 other person Thank this.
Rideandrepair and D.Tibbitt Thank this.
Get it done at a shop, you have to also replace the air dryer and flush the lines.
wis bang, Bean Jr., Rideandrepair and 4 others Thank this. -
InTooDeep, Flat Earth Trucker, Bean Jr. and 6 others Thank this.
Drain your air tanks and see what comes out first.
What engine?Rideandrepair, Magoo1968, JoeyJunk and 2 others Thank this. -
Also check your trailer air lines. Probably see some oil in them. Get it fixed ASAP or your going to have some serious problems down the road. Probably will need to change the air drier cartridge now and again when the cold weather starts.
Rideandrepair, Tb0n3, JoeyJunk and 2 others Thank this. -
InTooDeep, 77fib77, Dave_in_AZ and 2 others Thank this.
That looks like transmission oil to me. That oil would be black if it was from the engine. The lines out of that valve go down to the range and splitter pistons in the transmission. Bet you've got one with a blown o-ring and its letting transmission oil bypass. Every time you shift the range or splitter it exhausts a little bit of oil out of the knob along with the air.
Northeast Hillbilly, Flat Earth Trucker, Bean Jr. and 12 others Thank this.
Page 1 of 4
