Oil Change Interval
Discussion in 'Ask An Owner Operator' started by wadeenterprisesllc, Aug 9, 2022.
  1. wadeenterprisesllc
    wadeenterprisesllc Bobtail Member
    11
    6
    Jun 9, 2022
    New owner/operator, bought a 2015 Freightliner Cascadia with the DD15 from Ryder…Detroit says it’ll go 60k between oil changes for OTR. That just seems too long to me, but should I trust it?
  3. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    Oil is pretty cheap, relatively speaking. Sure couldn't hurt to shorten that up a bit. Say 30k
  4. staceydude
    staceydude Road Train Member
    1,143
    4,985
    Apr 3, 2020
    I would literally crawl out of my own skin every time I started my truck if I waited even 30k between oil changes.
    Vampire, BoostedTeg, D.Tibbitt and 9 others Thank this.
  5. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    25k for me, almost a million on my Volvo and great Blackstone reports.
    60k is madness. If that's the interval it's been changed at since new I would not buy the truck.
  6. Ridgeline
    22,103
    113,210
    Get an oil analysis before you do anything.
    then get the oil changed if it hasn’t been,
    then at specific intervals get another OA done and see what the results are.
    The OA will tell you when to change the oil before the manufacturer’s recommend mileage.
  7. Long FLD
    Long FLD Road Train Member
    11,366
    45,785
    Mar 4, 2015
    Depends on if the engine has some bypass filtration built in or not. After dropping the initial oil at 5k I ran 50k on mine. Sample came back good and I probably could’ve gone up close to the 75k service interval.
    I’m not sure what the criteria is for Detroit, but with a Paccar if you’re under 80k gross, above 6mpg, and less than 20% idle time the book recommends 75k.
  8. wichris
    wichris Road Train Member
    4,243
    8,447
    Jan 17, 2011
    DD15 severe duty 35K, long haul 60K
  9. 77fib77
    77fib77 Road Train Member
    10,167
    62,764
    Jul 7, 2010
    St Louis
    My dd15 I go 15 to 20k. It's like $300 with land star discount out the door. Sometimes 350. 23 k to rebuild the engine or just dump the oil when you have weekend and it's slow. If I push out a rebuild by 70k miles I'm ahead.
    bzinger and Rideandrepair Thank this.
  10. Arctic_fox
    3,861
    19,418
    Sep 16, 2016
    Depends on how you use it. I climb mountains at 80k on a regular basis so i do mine at 10k or when it starts turning black. Others go to 30k and i know a few who use full synth that go to 50k but they also tend to be a lot nicer to their rigs then i am to mine.
  11. nikmirbre
    nikmirbre Road Train Member
    5,371
    9,543
    Jul 27, 2011
    High Point NC
    Speaking of oil changes...I changed mine this weekend and couldnt find all the gallons of Rosella so I mixed a gallon of Lucas and 2 bottles of Synthetic .......
    Scared me cause my oil PSI dropped from the normal 60ish to about 45 ish!!!
    Back in late 90s early 2000s, Schneider use to change their oil at or around 75k.....
    Rideandrepair Thanks this.
  12. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    They didn't give you a manual with it? Could probably get one from FL.
