Oil analysis
Discussion in 'Trucks [ Eighteen Wheelers ]' started by silver dollar, Aug 21, 2012.
  1. silver dollar
    silver dollar Medium Load Member
    481
    210
    Jan 31, 2009
    Central North Carolina
    I want to start doing oil analysis on my truck. Is there somewhere to have this done. Can someone fill me in on how to get this done. Thanks
  3. yesyoubad
    yesyoubad Bobtail Member
    40
    14
    Aug 14, 2012
    Point Blank, TX
    Go too eoilreports.com
    make sure take sample when oil is hot
    silver dollar Thanks this.
  4. LBZ
    LBZ Road Train Member
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    What kind of motor are you running? Maybe your local CAT/Cummins/Detroit outlet has a program. Altorfer CAT around IL has a deal where you mail in the sample, was $11 but thinking it has went up a couple bucks.
    Have heard mixed things about Speedco results. Never used them & just what I have been told.
    http://www.blackstone-labs.com/ <~ Heard good things about these guys.
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    why ? wont the sample be cold when it arrives to destination?
  6. silver dollar
    481
    210
    Jan 31, 2009
    I have a Cat engine. I found the Blackstone web site and sent for a test kit. Their single test is $25. They offer a prepaid plan of 6 and 12 tests for $19. After I do the first one to see what my engine is doing, I plan to get one of the prepaid plans
  7. Dice1
    Dice1 Road Train Member
    1,315
    609
    Jul 1, 2011
    Bessemer City, NC
    Speedco does all my oil analysis with no problems.
  8. Licensed to kill
    Licensed to kill Heavy Load Member
    830
    2,434
    Dec 31, 2010
    Alberta
    I would think that a cold sample would mean that the oil sat long enough for some possible contaminants (antifreeze, diesel, particulates) to separate or settle throwing out the accuracy of the sample.
  9. rollin coal
    rollin coal Road Train Member
    13,077
    25,826
    Mar 29, 2008
    TN
    Maybe the sample is heated and/or shook up when they test it? For years I have read comments from guys about mailing their samples off to Blackstone, catching boost leaks, trace coolant in the oil, and things they wouldn't without sampling - happily fixing the issue sooner rather than later after ill effects have gotten worse - saving them money. So I have to think the "cold oil sample" thing is a non-issue but I could be wrong.
  10. LBZ
    1,771
    1,266
    Oct 22, 2008
    Road to Nowhere
    If heat were a issue, the labs would put out a statement on the bottles. Heck, even one would be the stand out if it deemed necessary.
  11. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Oil does not have to be fresh from the engine hot to run analysis on it. The labs will agitate the bottle to mix things up and it is heated to 100 degrees celsius during the testing to confirm the viscosity. That is hotter than it came from your pan.
    The on site sample machines work fine and are a quick check. I use on site testing frequently, and send in an occasional sample to a lab to double check things. One thing about an on site, you get the results right there, right now. With a lab it usually takes up to 5 days to find out something. If you have a major coolant leak, that 5 days may be enough running to really mess up things internally. Or any number of other problems that one could catch early by using on site. The labs are more thorough and trustworthy for the minor details and such. Virtually all the on site machines will give you a good ballpark analysis and catch the big stuff that is going on like bearings failing, etc.
