Off Time Due To Hernia Operation
Discussion in 'Driver Health' started by terryg247, Mar 16, 2019.
  1. terryg247
    terryg247 Light Load Member
    268
    133
    Feb 1, 2015
    Ontario, Canada
    i have to get surgery done to fix a hernia in the groin area and have been receiving mixed info regarding healing time and returning to otr. Any one been through this and how long til you were back on the road
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    I was back to work next day, just light duty status-do not lift anything.
  4. Farmerbob1
    Farmerbob1 Road Train Member
    3,685
    5,791
    Jan 17, 2017
    What does your doctor say?
  5. buddyd157
    buddyd157 Road Train Member
    13,506
    34,549
    May 25, 2017
    under a shade tree
    i had a bilateral (this means one on each side) hernia back in the early 1980's.
    back then, there wasn't any screen that they use today. i had to be sewn up inside, then of course outside.
    took nearly 6 months to fully heal, and one side, took longer to heal..
    back to work after doctor released me 7 months later. (short physical therapy sessions) for a month. luckily for me too, i did not have to load/unload any freight at that carrier.
    terryg247 Thanks this.
  6. terryg247
    268
    133
    Feb 1, 2015
    Ontario, Canada
    At least four weeks. Doctor is concerned about being seated for long periods at a time while healing
  7. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    yeah, my doctor wanted me to get up and walk around the house every hour or so......you ain't gonna be able to climb into that truck and out that often....
    Tb0n3 and terryg247 Thank this.
  8. Farmerbob1
    3,685
    5,791
    Jan 17, 2017
    This sounds like a reasonable precaution. If you are a company driver, maybe you can get some light duty work or short term disability?
    If you have to climb into the back of a trailer after surgery, you likely won't appreciate it much.
  9. terryg247
    268
    133
    Feb 1, 2015
    Ontario, Canada
    I drive for a mega. Have not told them about the situation and will not til it’s scheduled. Canadian health care being what it is the actual operation is months away. Not sure what their response will be
  10. buddyd157
    13,506
    34,549
    May 25, 2017
    under a shade tree
    sheesh, months away..??
    that thing can tear open bigger....
    good luck.
  11. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Much Bigger.
    I had one done at age one. About as early as they dared do it, its still present. Realm of microsurgery in those days as small I was then.
    When I had the appendix taken out doc said stay home 6 weeks, I was rolling within three. From what i understand via the surgeon's report that entire area is full of scar tissue preexisting so there must have been other work or injury to that region at some point in my life. He did explore and make sure that it's not going to be more of a problem than it was already.
    In your situation with a actual tear going on, you do not want to aggravate it any more than it is already. It can go from something that might be done later to something that is a true emergency in a hurry. Particularly if your guts start spilling against your skin layer bulging outside of the body as it tears bigger.
    If that does not scare you into fixing it soon I don't know what will.
    buddyd157 Thanks this.
