Off and on vibration every 5 seconds
Discussion in 'Trucks [ Eighteen Wheelers ]' started by PJM41, Sep 13, 2020.
  1. PJM41
    PJM41 Bobtail Member
    20
    Oct 26, 2018
    Hi all, yesterday I picked up a 2015 Mack CXU613 I purchased and drove it home 650 miles. The entire trip between 55-65 MPH the entire cab would vibrate off and on for a few seconds at a time. It is most notable from 61-63 and starts to even out again as speed approaches 70. I even believe it does it some at lower speeds like 25-35.
    If powering through those speeds withfull throttle, it is much less notable (though I am only in this speed range a few seconds when giving full throttle) and it is often most notable when releasing the accelerator.
    it feels like you are driving on unevenpavement and can be felt through the entire cab- floor, seat, steering wheel,side walls and even the hood can beseen vibrating.
    Any ideas?
  3. Judge
    84,378
    Going to have to narrow it down a bit.
    I’d say check driveline, carrier bearings, U joints to start.
  4. rachi
    rachi Road Train Member
    4,246
    5,228
    Feb 25, 2010
    SoCal
    First thing to check would be wheel balance and maybe a flat spot on one of the tires. Was it doing that when you test drove it?
    magoo68 Thanks this.
  5. PJM41
    20
    Oct 26, 2018
    I’m sure it was there on the test drive, but I only ran about 10 miles of highway and was testing different speeds, engine break, etc. also it really does just feel like you are rolling over a small stretch of rough road. It took an hour into the trip home to recognize the pattern.
    A friend of mine thought it could be too long of a leveling rod causing the suspension to be over inflated?
  6. Lysdexis
    Lysdexis Road Train Member
    4,483
    47,940
    Oct 25, 2018
    Check the carrier bearing. Or replace it anyway, I chased a vibration in a 2017 Pete 579 for months and finally replaced the carrier and it pretty much all went away. Mine would do it around 65 to 70 and then stop until about 85. On throttle or off the throttle didn't matter.
  7. bad-luck
    bad-luck Road Train Member
    3,242
    5,937
    Nov 16, 2013
    Baltimore, Maryland
    I would start with the tires. Do they have an uneven wear pattern, flat spots ect. Then check the drive line, u-joints, carrier bearing.
  8. BoxCarKidd
    BoxCarKidd Road Train Member
    4,417
    6,430
    Aug 26, 2014
    Have a couple of those here. Different drivers and different tires. Still trying to figure that out myself.
    They were all transfered here with some mileage on them. Wondering if the driveshafts yokes should be off set as someone else pointed out in an other post.
    The yokes on those are longer than standard shafts. We had to replace an inter axle shaft on one of those. Went to the local driveshaft shop. Fit in and looked fine. A couple of weeks later had a worse than usual vibration compliant. While driving over very uneven ground the short yokes pushed against the strap bolt heads and spread the yokes. Bought through shaft and rear pinion yokes, plus driveshaft from Mack. Problem solved but the driveshaft shop talked in circles. I set them pictures.
  9. SmallPackage
    5,273
    16,440
    Dec 20, 2019
    Marion Texas
    I just chased down a vibe and made a tread about it. It was a vibe that only happened in 7th dir or od at 40-50 mph. Turned out to be an ever so slightly loose trans output shaft yoke nut. Could not see any movement in it when shaken by hand. Only thing that gave it away was a little oil leak started from between the nut, washer and yoke. Seal did not leak.
    Doesn’t sound like the same vibe but worth a check anyway.
    BoxCarKidd and spsauerland Thank this.
  10. xsetra
    xsetra Road Train Member
    5,092
    6,939
    Aug 21, 2011
    I have a similar vibration. It starts strong about 45 thru 55. Speeding up, steady speed in the range or slowing down. Faint at other times. I think depends on the road surface.
    Tires OK no odd wear patterns on truck or trailer.
    The cause I found today.
    The Nut on the drive shaft that the U-joint is near the carrier bearing.
    Doing LOF today found it with flashlight. Usual inspection without the extra light, I couldn't see the faint rust trail or see the visible, very slight movement, behind nut on shaft.
    SmallPackage Thanks this.
  11. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    A vibration like you describe can be a wheel end. Brake drum out of round, tire not on rim evenly, but most likely sounds like a loose wheel bearing.
