oem cat or ipd parts for a 4mg cat rebuild?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by bjrc, Sep 14, 2018.
  1. bjrc
    bjrc Light Load Member
    81
    96
    Sep 14, 2018
    Will be a working truck not turned up a lot.
    Reason for edit: new guy
  3. T800H
    T800H Medium Load Member
    608
    295
    Apr 2, 2010
    The Keys
    I went the IPD way a year and 100k miles a go, 3406E, did it my self, I'm a O/O not a mechanic.
  4. bjrc
    81
    96
    Sep 14, 2018
    Thanks for the response. Years ago I would say cat only, now not sure there stuff is worth the extra money.
  5. AModelCat
    154,214
    No first hand experience but I've asked this same question on other forums and it seems that IPD makes a decent kit. I will likely be going that way on my hobby truck unless my company discount on Cat parts is comparable to IPD.
    @superhauler @SmokinCAT
    peterbilt_2005 and Oxbow Thank this.
  6. bjrc
    81
    96
    Sep 14, 2018
    On another thread they used ipd and had problems with oil consumption, but was said ipd had better rings now. The old truck runs good just uses oil and has blowby, didn't want to waste my time and money rebuilding and not improve it.
  7. dustinbrock
    dustinbrock Road Train Member
    1,308
    901
    Apr 19, 2012
    North Battleford, SK
    Fp Diesel by Federal Mogul is what I used. Brand new Mahle Pistons. If you are not familiar with Mahle, they make most of the OEM pistons.
    Now that being said, I cannot tell you longevity or anything as I am rebuilding mine again after 4 months cause the mechanic didn't cut the counter bores with a 10 thou dip on the flange. I can tell you they still look brand new but after only 4 to 6 months.... I would expect that.
    SAR and Justrucking2 Thank this.
  8. bjrc
    81
    96
    Sep 14, 2018
    I have two different o/o friends that had their 3406 e rebuilt, (complete inframe with cat parts) at two different dealerships for big money and neither truck ran 6 months before head gaskets began leaking. Both places said liner projection was good. Then they were charged a lot more money to repair them the second time! Will be doing mine myself no matter how long it takes, may have to buy a counterbore cutter but probably still cheaper in the long run. Yes mahle builds a very good piston for many applications but liner projection has to be in specs or they wont last. Am also concerned about head gasket quality in these aftermarket kits.
    Hawk6275 and Justrucking2 Thank this.
  9. wore out
    wore out Numbered Classic
    15,319
    184,946
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    I have used PAI, IPD in several. I can't stress enough how important liner protrusion is. Head bolt torque, holes being clean and properly lubed is just as important. CAT parts are not what they use to be for sure. I have heard of missing or broke rings on the pistons. Since they come loaded most don't check. I will say I have never found anything like that.
    Quality parts and attention to detail on installation is key for an overhaul to last.
    PSM379, bigguns, SAR and 4 others Thank this.
  10. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    If your doing a kit I believe there’s a big difference in the warranty between the 2 companies.
    Ipd is 12 months only, Cat will sell you up to 4 years I believe.
    bigguns and Heavyd Thank this.
  11. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    IPD warranty is 2 year unlimited mileage for on-highway engines.
    snowman_w900, SAR and Cat sdp Thank this.
