Odometer stopped working on 98' FLD120
Discussion in 'Freightliner Forum' started by Iron-Man, Aug 30, 2016.
  1. Iron-Man
    Iron-Man Light Load Member
    58
    97
    Apr 14, 2016
    Oklahoma
    I noticed that my odometer stopped working yesterday. I went to make a note of mileage when I crossed into a new state and I thought to myself, "Wait a minute... that's where it was when I left the shipper!" It was just stuck. I banged on it a little and it started scrolling again but would stop again after about a mile.
    The tachometer and speedometer work just fine. I need to find out how to get it working again and adjusted now to the correct mileage because now it's about 500 miles behind.
    Any ideas or anyone else have this happen before?
  3. David_Simpson
    David_Simpson Medium Load Member
    650
    637
    Feb 23, 2016
    try and get under the truck and look for the cable. when found, remove it, try spinning the gear, if one is still on the cable end.
    on another note, maybe it became disconnected at the dashboard? try removing the dash cluster and check if it is still connected to the speedo head.
    cable are known to break, and since you truck is so old, that's what could have happened, IF the plastic gear did not explode first.
  4. wore out
    wore out Numbered Classic
    15,319
    184,961
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    That truck is electronic. Also if the speedo works but odometer doesn't a new speedo is the only fix. Usually a sticker is put in door jam replaced at x mile's.
    BoxCarKidd and spyder7723 Thank this.
  5. Iron-Man
    58
    97
    Apr 14, 2016
    Oklahoma
    Yeah that's what Freightliner just told me...the whole speedometer thing would have to be replaced. When I asked about the miles being reset to where it's accurate he said the odometer would start at 0. Kind of makes me wonder now when buying these older trucks seeing how you don't know if the odometer is accurate or not... Anyone know how I should handle my IFTA reporting after something like this happens and I have to start at 0?
    desperado75 Thanks this.
  6. spyder7723
    spyder7723 Road Train Member
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    Just make a record of the old odometer reading and the new one. For the miles in between when it wasn't functioning do the best you can using google maps or with an atlas.
    As for your concern about buying an older truck, that's why you always pull the ecm records. The ecm keeps track of mileage also. But it can also be changed, so that's no guarantee.
    Iron-Man and wore out Thank this.
  7. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    When I bought my 2000 fl it had quit counting the distance also. It quit at 1,864,xxx. (Km) I think it quit because it sat for a year or 2 before I bought it. The solution was a new speedo unit.
    Iron-Man Thanks this.
  8. Iron-Man
    58
    97
    Apr 14, 2016
    Oklahoma
  9. Iron-Man
    58
    97
    Apr 14, 2016
    Oklahoma
    Oops forgot to throw the text in...anyways, yeah it looks like I'll be getting another one...kind of expensive though. Freightliner quoted me $315. I called some parts store but they said that particular part on my model was a Freightliner only part...there isn't any aftermarket versions. I was thinking maybe $200 at the most but I guess it's not a big deal, just annoying to have to go back and manually calculate miles especially since I probably won't have it done til this weekend because noone seems to carry it in stock and I'm not gonna miss a load waiting on that. But I'm not going to complain about it much...I'm doing good out here so far and I know there is much, MUCH worse that can happen.
  10. TankerYankr
    TankerYankr Medium Load Member
    303
    470
    Jan 16, 2010
    Central US
    A working odometer is not a DOT requirement, as long as your speedo is working you are good to go legally.
    You may also use a mileage program for figuring your IFTA mileage. These items would save you a few bucks from having to replace the speedo unit.
    You may also want to consider bolting a hub meter on one of your drive axles, this would give you exact mileage if you prefer, I think they are much less than $315.
    Iron-Man and David_Simpson Thank this.
  11. spyder7723
    15,467
    25,009
    Mar 31, 2013
    sarasota, fl
    While it's not needed and you could get a hubometer, if a guy can't spend 300 bucks to fix his odometer just for convenience, he is part of the problem out here with freight rates.
    300 doesn't even qualify as pocket change when dealing with trucks.
