OAT sensor
Discussion in 'Peterbilt Forum' started by DieselDog81, Apr 6, 2013.
  1. DieselDog81
    DieselDog81 Medium Load Member
    415
    213
    Apr 7, 2012
    Between here and there
    My OAT sensor isn't working, just comes up as a bunch of dashes on the display. Is there a cheap/easy fix for this that anyone knows of?
  3. eeb
    eeb Heavy Load Member
    731
    268
    Mar 24, 2013
    Brain fade, what's the OAT sensor?
  4. TruckingSurveyor
    TruckingSurveyor Light Load Member
    133
    43
    Jan 28, 2013
    Oregon
    Not OP, BUT I think OAT = Outside Air Temperature
    TS
    eeb Thanks this.
  5. eeb
    731
    268
    Mar 24, 2013
    Weather channel app?
  6. eeb
    731
    268
    Mar 24, 2013
    Check for damaged wires or corroded terminals in that circuit. Don't know where that sensor is located on that truck, try looking behind the front bumper or grill.
  7. DieselDog81
    415
    213
    Apr 7, 2012
    Its on the underside of the drivers side mirror
    eeb Thanks this.
  8. GrapeApe
    GrapeApe Road Train Member
    2,215
    2,211
    Jan 7, 2013
    It's the little black thing riveted to the bottom of the drivers side mirror. I don't have the part #, but they are available separately from the mirror, but you have to find a dealer that cares enough to look into it, most want to sell you the whole mirror.
    First step is to check the wiring, but if you do need a sensor, don't let a dealer tell you that you have to buy a whole mirror.
  9. eeb
    731
    268
    Mar 24, 2013
    Ha! Had the local peckerbilt dealer tell a driver he had to buy a complete taillight assembly because he had a taillight out, and there weren't any screws in the lens. I slid the lens out of the grimmer, replaced the bulb, and checked my work- sometimes the dealerships are less trustworthy than a lowly truckstop shop.
  10. GrapeApe
    2,215
    2,211
    Jan 7, 2013
    I wouldn't say that the Pete dealer that tried to sell me the whole mirror was dishonest, just not willing to look farther than what the Pete system said. In the Pete parts system, there is no breakdown of the mirror, so the simple answer was to sell a whole mirror. It was actually a Kenworth dealer that took the extra initiative, because they agreed that it was nonsense to replace a $350.00 mirror for a sensor. This was about 2 years ago, so I don't remember the part #, but it was like $65.00 for the sensor.
    We didn't really care about the sensor at first, but the heated mirrors didn't work, I was told that they use the OAT sensor because they only work when it's cold enough to need them. The sensor fixed the mirror issue. The A/C did work, but I was told that the A/C uses the sensor to disable the A/C below freezing.
    SL3406 Thanks this.
