06 freightliner fuel cap leaking help
So I have changed the gasket, sealing surface is smooth.
Why does this thing still leak.
It seems to be coming out this plug on the top.
I'm assuming its some kind of vent but why is it needed if the tank is already vented off the top with vent lines to leak on to the ground.
Leaks worse the more fuel is in it.
Since the tank is vented can I weld this round plug on the cap shut?
O6 freightliner fuel cap leaking
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Jd9760, Dec 22, 2023.
Fuel Caps leak! | Page 2 | TruckersReport.com Trucking Forum | #1 CDL Truck Driver Message Board (thetruckersreport.com)
Also this.
How to Stop Fuel Cap Leaks on Heavy Duty Trucks - Heavy Truck Solutions
Good idea to check the vents coming off the top of the tank. Blow through the vent and hose.Rideandrepair Thanks this. -
If you have the type were a freeze plug wont work then a simple dab of JB weld will work. Frieghtliner had two piece screw on caps back before the ones you have came out that would leak were the 4 rivets fastened the dome top on. JB also solves that.
