Nursery Tarps
Discussion in 'Flatbed Trucking Forum' started by Blind Driver, Apr 23, 2013.
  1. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    What qualifies as a nursery tarp?
    Is it just big see though netting?
    What would I buy such a thing?
  3. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    A mesh tarp is what I use. I buy mine from a nursery supply here in tn. where I live.Standard size is usually 16x55.Aywhere from $165.00 to $265.00 depending on the weight of the material.Some tarp shops make them also.
  4. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    I use them hauling nursery stock, sod, trees. Made out of see-through netting.
  5. MJ1657
    MJ1657 Road Train Member
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    I have mesh tarps that I use when we used to haul some sod loads. Not sure on the length but they are 16 wide. Takes two to cover a full trailer.
    They work good for loads that just require a tarp to keep shrink wrap or packaging from coming off.
    SHC Thanks this.
  6. BlueSparrow
    BlueSparrow Light Load Member
    53
    42
    Apr 5, 2013
    You need to cover plants so the wind does not shred them to pieces.
  7. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Most of the time, those are used for low speed local hauls.
  8. MJ1657
    7,521
    50,150
    Jan 28, 2012
    Isanti, MN
    Sod guys wanted the mesh tarps. Regular tarps would cook the sod. Mesh tarps keep the sod from drying out to much.
  9. ost1
    ost1 Light Load Member
    54
    22
    Mar 28, 2013
    I use them to haul in the spring... big trees. they aren't cheap but when the trees are running and you have them . you can make really nice money if you know the right folks.
  10. Blind Driver
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    I am seeing nursery load going for more then $3 a mile :biggrin_255:
  11. Stryder
    Stryder Bobtail Member
    11
    5
    Feb 10, 2013
    We use them for our B&B nursery loads, a regular tarp will quickly cook a tree.
    John
