NOx Sensors code
Discussion in 'Volvo Forum' started by Espey127, Jun 30, 2021.
  1. Espey127
    Espey127 Bobtail Member
    49
    11
    Dec 13, 2016
    2020 Volvo VNL 760 D13
    Tripping codes....NOx Sensors are open
    P220513
    P220013
    Parked overnight, woke up with both codes active. Any idea how to further troubleshoot this issue?
  3. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    Unless you have the PTT the dealership.
  4. AModelCat
    154,267
    Without diagnostic software all you can really do is visually inspect the sensors, wiring and plugs for obvious signs of damage.
  5. Espey127
    49
    11
    Dec 13, 2016
    Thought so, thanks.
  6. matmslash
    matmslash Bobtail Member
    10
    9
    May 16, 2014
    Try to do a parked regen, I use www.truckingse.com to find local shops to get in and out.
  7. Espey127
    49
    11
    Dec 13, 2016
    Any Diagnostic Software recommendations?
  8. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    Your issue could be several..One or both NOX sensors have failed. Could be wiring harness to the sensors. Could be a wiring fault somewhere else. Cost to have sensors replaced approx 2000.00 at a dealership. Cost to diagnose depends. Good luck
