nox sensor code
Discussion in 'Volvo Forum' started by NathanMullin, Oct 27, 2015.
  1. NathanMullin
    NathanMullin Bobtail Member
    38
    8
    Sep 29, 2014
    Vancouver BC Canada
    i got a 2011 670 with isx cummins and got engine fault code spn 5024 fml 10 which is after-treatment 1 intake gas nox sensor heater ratio abnormal rate of change. does anyone know where this sensor is located on the def system. dealer is telling me there are 3 but i think they may be thinking of the 3 temp sensors on the top (or maybe they are right for a change) ive tried google with no help or if anyone has the part number for it that would be a big help.
  3. wgierczynski
    wgierczynski Bobtail Member
    34
    14
    Aug 6, 2014
    You should have 2 nox sensors on inlet and one outlet
    KB3MMX Thanks this.
  4. NathanMullin
    38
    8
    Sep 29, 2014
    Vancouver BC Canada
    got it fixed back in october. it was the sensor just past the turbo. pain in the ### to change.
    KB3MMX Thanks this.
  5. Redhead770
    Redhead770 Bobtail Member
    Fayetteville, GA
    Yea I've got a 14 prostar with a Cummins ISX 15 400st and my check engine light came on and it throwing a SPN 3216 FMI 10 is this the aftermarket NOX behind the turbo or on the DPF plz help I can do the work myself once I know what and where it is. Thanks in advance
  6. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    In my 2010 and my last 780/ 08, nox sensor is located on exhaust pipe, just behind dpf, and is hooked to a module located
    inside the frame, right side ,above DPF. Expensive, aprox.500$
