Not good at gear ratio, and fuel mileage. 3:21 gears
Discussion in 'Ask An Owner Operator' started by Phumac, Sep 11, 2018.
  1. Phumac
    Phumac Light Load Member
    62
    32
    Jun 4, 2014
    Hi. Thinking about purchasing a truck. 2014 Freightliner Cascadia With a Detroit DD 13 with a 3:21 gear ratio. I don’t really understand the whole gear ratio thing yet . Is this OK ? I pretty much just run Kentucky to Chicago and back . Thoughts?
    Thank you
  3. Arkansas
    Arkansas Medium Load Member
    514
    667
    Dec 20, 2014
    LA- Lower Arkansas
    What Transmission ?
  4. Phumac
    62
    32
    Jun 4, 2014
    It’s a 10 speed . That’s all I know so far.
  5. Arkansas
    514
    667
    Dec 20, 2014
    LA- Lower Arkansas
    Your gonna have a big gap between 9 and 10. It will be ok. But won't pull hills the best.
  6. Phumac
    62
    32
    Jun 4, 2014
    Ok thank you. Will it do ok with gas mileage?
  7. Arkansas
    514
    667
    Dec 20, 2014
    LA- Lower Arkansas
    Not sure about fuel mileage.
  8. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    The only way to know that really is try it, in theory it should be but you never know.
    Phumac Thanks this.
  9. ChicagoJohn
    ChicagoJohn Road Train Member
    2,387
    2,749
    Jan 14, 2016
    Chicago
    A 3.21 rear isn't going to scream up a hill, but you should be able to get good fuel millage.
    As rule, the lower ratio (3.21, 3.36, 2.64, 3.42) the better you'll do fuel economy wise and they're fine for flat land.
    The higher ratio (3.73, 3.90, 4.11 +) you'll climb better but "to out" earlier and at highway speeds have a higher rpm. Heavy haulers would fall into this category. They don't need to hail ###, but need help getting up to speed.
    I've always heard a 3.55 is about the beast all around rear gearing. But again, it's really going to depend on what the application is.
  10. blairandgretchen
    13,212
    70,209
    Dec 9, 2011
    South west Missouri
    Pretty good all round answer. 3:42 to 3:58 gearing, you can't go too far wrong. Research your gearbox final drive ratio just in case.
    TripleSix and ChicagoJohn Thank this.
  11. Ridgeline
    22,101
    113,192
    Take the serial number to the dealer, ask them specifically what 10 speed is in the truck and then walk up to the front sales area and ask them where the sweet spot of the engine is with that trans and rear end. This is where you want the truck to operate at for mileage.
