Not For Hire
Discussion in 'Ask An Owner Operator' started by careycal64, Apr 8, 2022.
  1. careycal64
    careycal64 Bobtail Member
    11
    7
    Feb 11, 2022
    Hi all,
    I've been looking for the right answer for this everywhere to no avail. I get a mix of answers that contradict each other or just sound unreasonable. I'm not a law breaker (usually) so I want to do this right.
    My wife and I are moving from California to Virginia. I already have a CDLA, so I bought a single axle Volvo and a 53' dry van trailer. I'm loading all of our belongings into the trailer to haul from California to Virginia.
    When we get the truck and trailer to Virginia, we plan to sell it.
    So, 1 cross country run, no commercial intent, then I'm done.
    I own the truck and the trailer and there is no commerce involved. The combined weight will likely exceed 26,000 lbs which I believe is the magic number for triggering many regulations.
    Will I need a DOT number? FMSCA number? Will I have to pay fuel taxes and weight fees in each state I cross? Will I be drug tested (not that this is a problem, just want to know).
    Any advice on making this run in the least expensive and reasonably law-abiding way is appreciated as we are not wealthy, which is why I'm going to the trouble to move my own stuff. And I sure as heck can't afford to have all of my stuff seized for being ignorant.
  3. 062
    062 Road Train Member
    6,417
    34,320
    Oct 20, 2013
  4. larry2903
    larry2903 Heavy Load Member
    799
    1,006
    Oct 18, 2009
    On the trails
    How is the truck registered? If registered as private ownership then you should be able to sticker “ NOT FOR HIRE “ on the side of the truck and roll. I think, but I’ve never done this.
    Vampire Thanks this.
  5. kranky1
    kranky1 Road Train Member
    2,253
    8,856
    Sep 16, 2015
    Ontario, Canada
    You would be a private carrier. Enforcement isn’t as fascist when you’re not hauling for hire. Your truck, your trailer with your belongings on it. Still have to be in compliance, licences and insurance, log and mechanical fitness, and the taxes, highway use and fuel. But beyond that they have no reason to mess with you a whole bunch. You don’t even need a Bill of Lading, in your case a Manifest. The list you give the insurance company to show what they’re covering would satisfy that. I might suggest calling a permit service, tell them what you’re doing and they’ll tell you what you need for permits. If the permits are in place before you let the clutch out you’re already ahead of most of the bad that could happen.
    omardten Thanks this.
  6. omardten
    omardten Bobtail Member
    4
    Jan 22, 2022
    As long as you have insurance,and registration or temporary tag, I have called or emailed a scale house in each state because each state will have different rules, some will want you to pull in, other scale houses want you to bypass the scale. Not for hire stickers are not required, but sticking them on the side of the truck and back end of the trailer reduced pull overs from the DOT for questioning. Drug testing has only been required for hire. Fuel tax for most states when not for hire are paid at the pump.
  7. Ridgeline
    22,853
    126,517
    You need to register it as a normal vehicle in California.
    get insurance as you would as a pickup or a non-commercial vehicle.
    plate it as such.
    and go … you don’t have to deal with fuel taxes, you don’t need to worry about weigh stations or anything like that.
    Don’t even have to put not for hire on the truck because it is a personal vehicle and trailer with personal stuff on board.
    pete781693 Thanks this.
  8. Allow Me.
    10,813
    12,789
    May 28, 2009
    Rancho Mirage, Ca.
    The problem is, you look like a CMV. However, you do not have to do or comply with CMV rules. But, any police agency will think you are a CMV (commercial motor vehicle) until you prove otherwise. That means a paperwork check at the port-of-entry. Like N.M. for instance or Wy. Always open, I've noticed Az. POE at Ehrenberg on I-10 is always closed. Tx. should be easy, I would put "Not for hire" on the doors, a backwoods enforcement grunt, with any luck, will notice that and probably NOT pull you over. I mean, think about it, how many NON truck drivers buy a truck/trailer to move themselves ? Have fun out there. :bootyshake:
  9. RocketScott
    RocketScott Medium Load Member
    579
    949
    Apr 10, 2013
    Kentucky
    I just did this last year, except I went from Washington to Kentucky in a boom truck pulling a 28' trailer
    Weight doesn't factor into it, my truck weighs 33,500 by itself and I can still drive it without a CDL
    Don't need a DOT number, FMSCA , fuel tax, weight fees, drug test, etc.
    Some states I went through wanted everyone to stop at scales (even RVs) and others only require commercial vehicles to stop. Never got pulled into the scale house at the ones I did stop at. I have "Not for Hire" on the doors even though it's not required. No idea if that made a difference for not being pulled in but it certainly didn't hurt
    I'll send you a private message. I made a printout of all the laws that pertained to what I was doing in every state I went through. Most were clear that I was 100% legal. Some, like Iowa, weren't super clear. Fortunately I didn't have any issues on the move, but I have had to give lessons on the law when I lived in WA
  10. wore out
    wore out Numbered Classic
    18,267
    231,640
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    1 run and done? I know what I would do....I’d let East bound Az close and ride on by. I’d act like the New Mexico port wasn’t there. Texas be closed and Oklahoma and Arkansas be easy to get around. I’d plate it as a pickup etc for personal use and put not for hire on it. Plead ignorance should you get asked. Lots of different opinions and lots of scary if if ifs. In truth there are not lookin to hang anyone especially a guy like the OP. Reason I say stay off the coops is no need invites to questions and anal probes. If you do everything that’s gonna be advised by some you’ll save nothing and have more headache than just leaving your current #### behind and getting all new #### in VA.
    Again my opinion won’t be popular however for what your doing it’s the most practical. It’s not a big deal to get from the west to the East and never go in a government funded robbery point
    406newbie, RefMata, BigCam9670 and 5 others Thank this.
  11. W923
    W923 Road Train Member
    1,461
    4,552
    Feb 28, 2022
    Only trouble can come from scales so avoid them, otherwise I probably wouldn’t worry about following every last rule. Not going to be very practical but if you travel at night or in rainy weather you will be much less likely to be questioned. They’re not going to get wet unless they think there’s a payday coming. As long as you have registration and insurance and can explain what you are doing and it’s believable they will most likely turn a blind eye as long as you don’t do anything stupid or have a wreck. the sad part is that we even have to have this discussion.
