Normal or not, smoke coming out of the bunk heater?
Discussion in 'Experienced Truckers' Advice' started by Trucker327, Feb 8, 2019.
  1. Trucker327
    Trucker327 Light Load Member
    176
    20
    Dec 24, 2017
    Does anyone know.. If it's normal or not.. When you turn on the heater under the bed and smoke starts coming out the back? it's 24degrees outside.. Put the heater on and the smoke started.. I have a 16 freightliner Cascadia..thanks
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Yes that is normal.
    86scotty Thanks this.
  4. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Out the back, as in outside the cab?
    If so, yea thats the exhaust being blown out.
  5. SteveScott
    SteveScott Road Train Member
    4,897
    16,806
    Nov 10, 2015
    Outside the cab yes, inside no, and get out if it's inside.
  6. Cam Roberts
    Cam Roberts Road Train Member
    1,621
    1,938
    May 13, 2018
  7. Espressolane
    16,967
    102,251
    Some is normal, mostly at start up.
    Lots of smoke all the time is not good. You may need to have the unit serviced/cleaned. Usually takes about 2 hours to remove, rebuild and reinstall. To reset the unit, it takes a “ diagnostic unit” to plug into and reset the thing. Usually only authorized dealers/service locations have it. It will work without doing that, just will always display “ check heater” all the time.
    x1Heavy Thanks this.
  8. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    Always smoke outside.
    NEVER INSIDE. If you get it inside GTFO of there, it will probably cremate you if you lollygag around trying to gather up sentimental valuables.
    alds and BigDog Trucker Thank this.
  9. Ridgeline
    22,101
    113,190
    You guys need to run these heaters once a month every month for at least ten minutes.
    buzzarddriver and Long FLD Thank this.
  10. lowlife
    lowlife Bobtail Member
    21
    23
    Feb 21, 2017
    Minnesota
    You can reset it with a paper clip through that hole on the controller.
    Truckermania Thanks this.
  11. 86scotty
    86scotty Road Train Member
    4,373
    11,589
    Aug 27, 2017
    Appalachia
    I think if there was smoke inside the OP wouldn't be here typing this thread.
    My Espar smokes sometimes. Use regularly for best luck. Gotta keep the soot burned off with these units.
    OP, if you've never used the heater before you're probably just burning the factory gunk out of it.
    BigDog Trucker Thanks this.
