Normal Oil Pressure
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Mufflerbearing, Jan 16, 2018.
  1. Mufflerbearing
    Mufflerbearing Bobtail Member
    Hello, I am a rookie driver who will be posting lots of rookie type questions. I have so much learning to do and I appreciate any input you all can offer.
    I work for a company that uses many different trucks. From Petes to Macks to Western Stars and more. I have to drive all of them when requested. There is so much to remember about each truck. One issue I struggle with is normal engine oil pressure. Everything I have read shows different values for different engine types and sizes.
    Is there a general rule of thumb for normal engine oil pressure? As in 10 psi per 1000 rpm?
    Not having much experience, I don't know when to know if my oil pressure is too high or too low other than remembering what the gauge typically states as I drive it and assuming that is the normal.
  3. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    You're over think it. If you had low oil pressure, youll get a warning light. If you're still concerned look up specs for every engine youll be driving. There is no universal formula
  4. Dave_in_AZ
    370,353
    You'll find they all are around 35ish normal operating pressure.
    If you see it go up to like 45 or 50, or down to 20, you have a situation.
  5. Mufflerbearing
  6. Diesel Dave
    8,526
    23,505
    Jan 20, 2010
    Hesperia, Ca.
    My Cat idles about 42 and a peak it runs 65 to 68. On a long pull when it get pretty warm, it will get down to 62.
  7. BigBoTrucker!
    BigBoTrucker! Bobtail Member
    4
    Aug 28, 2020
    Just switched over to 2015 T680 with the Cummins, what's the norm for oil pressure for Idling and running at 1500 RPM
    I'm used to a C15 CAT in a 08 9400 international.
    Thank you in advance
    Slowrider89 Thanks this.
  8. A5¢
    A5¢ Medium Load Member
    389
    544
    Oct 30, 2017
    With your hopping from one seat to another, I would suggest using your phone to take pictures of the gauges, with cold /hot, low and high pressures. Do the same with the whole dashboard. I use my phone for a kinds of things like that.
  9. Brettj3876
    Brettj3876 Road Train Member
    11,257
    54,056
    Nov 18, 2014
    Land of local
    Gen rule of thumb most will be 45-70 ish range normal temps at highway speeds. And about half that when idle with a warm engine
  10. Brettj3876
    11,257
    54,056
    Nov 18, 2014
    Land of local
    The idiot light will go off if pressure drops and shut it down before it hurts itself
