No turn signals or hazards
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by coole99, Jan 22, 2018.
  1. coole99
    coole99 Bobtail Member
    32
    5
    Feb 26, 2008
    Pittsburgh, Pa
    I have a 05 International 9400i and my turn signals/hazards aren’t working. I replaced flasher relay and it shorts immediately along with fuse blowing. I check bulbs, traced wires (not behind dash yet), and relays. What am I missing?
  3. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    Maybe bad contacts in the relay panel causing it to arc and create an over amperage surge?
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    Do you have to turn on a turn signal or hazard switch before it shorts out?
  5. coole99
    32
    5
    Feb 26, 2008
    Pittsburgh, Pa
    No, as soon as I put the flasher relay in it shorts the fuse blows.
  6. Heavyd
    Heavyd Road Train Member
    7,751
    6,184
    Feb 4, 2009
    Ok, there is a flasher and relays for the signals. There is no flasher relay, so what is it that you are installing and blowing a fuse? Which fuse exactly? If you are installing the flasher and F2-D (20 amp) is blowing, after the flasher is the signal stat on the steering column. Something is shorted there or in the wiring between it and the flasher.
  7. coole99
    32
    5
    Feb 26, 2008
    Pittsburgh, Pa
    Ok, the f2-D (20 amp) is fine until I put the flasher in then the flasher short and fuse blows. Ok I’ll check wiring there. Do you think a bad turn signal switch could cause this?
  8. Heavyd
    7,751
    6,184
    Feb 4, 2009
    It sure could. Anything is possible. Simply unplug it and see of the short goes away. I hope you have breakers instead of fuses, LOL! If it keeps popping the fuse then it must be a wire rubbed through on something in the dash. The wire between the flasher and signal switch is orange in colour, 12 gauge in size and number 55A.
    spsauerland and coole99 Thank this.
  9. coole99
    32
    5
    Feb 26, 2008
    Pittsburgh, Pa
    Thanks for the help Heavy D!! The wire that was rubbing was behind the dash rubbing against the steering column. Thanks again!!
    Heavyd Thanks this.
  10. Heavyd
    7,751
    6,184
    Feb 4, 2009
    Cool! Great to hear you found it!
