No trailer turn signals
Discussion in 'International Forum' started by Bigbadben, Apr 8, 2015.
  1. Bigbadben
    Bigbadben Bobtail Member
    11
    I got 08 prostar I can only get LEFT REAR turn signal to work on trailer .... All marker and brake lights are working fine... Checked all fuses there good put brand new power cord on and still nothing working... Any ideas??
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Got a test light?
  4. Bigbadben
    11
    Yea I actually do
  5. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    K, just have to find where the signal is getting lost. I'd start by turning on only your left or right blinker. Take that test light and unplug the end of the pig tail that plugs into your trailer. Try to find where the current is flowing through, should be going on/off ... also try it for the other blinker, is the signal making it this far, for both sides?
    If you want to test your test light first just put marker lights only on then find whichever hole turns those on
  6. Bigbadben
    11
    Shouldn't the left side middle trailer signal be the same as the left rear??
  7. Bigbadben
    11
    Left side middle isn't working only the rear
  8. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    Yes - I thought all the turn signals weren't working?
    What is working and what isn't working?
  9. Bigbadben
    11
    Only thing WORKING is left rear on trailer .... No problem with tractor
  10. gokiddogo
    8,786
    14,766
    Mar 5, 2012
    Ontario Canada
    I'd say for left middle it's probably just a bad bulb ...
    For right side maybe you got a bad bulb in the middle and on the end but i'd do the test light check for right side at back of pigtail and if that is working line it up to whichever male end it plugs onto on the trailer, take off that box and see if signal is making it through that box ...
    I have had it happen where it was getting lost somewhere inside that box on front of trailer ... and fuses on it were all fine also ...
    flood Thanks this.
  11. xsetra
    xsetra Road Train Member
    5,094
    6,941
    Aug 21, 2011
    Whatever you do,don't get lazy and use the probe to poke thru the insulation to check the wires. You will only have a bigger mess in a couple weeks or months. Probably when you come to a coops and its raining.
    Also you could be losing your connection behind the trailer side of connection inside. Those terminals after a while will corrode and short out. My trailer has the main wires from plug go all the way to the back of trailer and then back up each side for the marker and turn light.
    Pull and check all your lights to see if the lights are bad or the pigtail. If you put a light you know is good in each pigtail as you test.
    Good luck. Electric gremlins can move and multiply.
