NO START 2010 MAXXFORCE DT
Discussion in 'International Forum' started by dcwjr, Dec 9, 2015.
  1. dcwjr
    dcwjr Light Load Member
    58
    Jan 11, 2013
    HAS LOW INJECTION PRESSURE-54PSI WITH A DESIRED OF 900PSI, CAN SOMEONE GIVE ME THE ICP LOCATION, UNDER THE VALVE COVER MAYBE? ANY IDEAS TO SPEED UP MY DIAG
  3. BarrettL82
    BarrettL82 Bobtail Member
    4
    Dec 9, 2015
    The ICP sensor is under the valve cover on the rail. Remove the Injection control pressure regulator and see if the screen is blown out. You may have a failed regulator. If not you may want to check pump pressure before removing the valve cover. I assume the engine builds good base oil pressure when this occured?
    AppleTownAuto Thanks this.
  4. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    I just spent a good bit of time with one of those. I knew nothing and now only know somethings. One thing I learned was on U tube look for DT466 IPR valve problems? HoglundBusandTruck has some good information, it is time consuming, and educational. I worked through mine without buying any special tools. Some self education would also help you isolate, correct the problem, and or know the questions to ask people like Barrett or HeavyD.
  5. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Not building icp pressure can be a few different issues. First, engine oil runs the high pressure side. Make sure you have oil in it. Then, for what ever reason it cannot build high pressure. Either there is a massive leak, pump failure, IPR failure or simple ICP sensor failure. Most common are the connector right at the IPR. There are updates for it. Then a simple test for the ICP sensor is to simply unplug the very front valve cover pass through connector and try to start the engine. If it starts, then the sensor is bad. After that you have to dig into it to see if the pump is bad, or you have a massive leak under the valve cover.
  6. dcwjr
    58
    Jan 11, 2013
    Thank you Heavyd, so its no different then diagnosing any other high pressure oil system
  7. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Not really, no.
  8. drdiesel
    drdiesel Bobtail Member
    15
    6
    May 12, 2013
    Earth
    Heavd , wondering if you are seeing many 2015 Maxx 9 or N9 { same crap} with the high pressure oil rail end plugs failing? Where the inner press in portion of the rail plug is coming out into the oil rail and breaking up and destroying injectors with metal getting stuck in spool valve portion??
  9. Heavyd
    7,749
    6,184
    Feb 4, 2009
    No, sorry. I have not heard of that.
  10. drdiesel
    15
    6
    May 12, 2013
    Earth
    Seen two in the last week, Figured I'd give you a heads up because you know how the dealer is the last to know from IH, rather then posting a note on ISIS soon as a issue comes up.
    Heavyd Thanks this.
  11. BarrettL82
    4
    Dec 9, 2015
    The dealers always see the issue before IH. Then it has to be investigated and confirmed before it gets to ISIS. The first line of knowledge is usually a IKnow article. Been on both sides of that coin.
