No more battery warranties
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Skate-Board, Oct 27, 2014.
  1. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    I knew this was going to happen. Napa is not warrantying any of their commercial batteries unless they have defective workmanship. Delco and others are soon to do the same. Things have changed so much in the recent years that trucks are now carrying a heavy hotel load with laptops, tv's, heaters, refrigerators and all sorts of other things. Batteries can only be charged and discharged so many times before they are no good.
    I know a guy that was buying Walmart deep charge marine batteries that were warrantied for 5 years. He was going through 4 batteries every year. After 3 years Walmart gave him a full refund and would no long honor use in a commercial vehicle.
  3. allan5oh
    allan5oh Road Train Member
    1,557
    556
    Jan 6, 2010
    Winnipeg, mb
    I don't understand why people go through batteries so much. Buy a good alternator, buy the RIGHT batteries, and make sure the connections are clean. They should last 2-3 years in almost any operation. I buy the 825 CCA cat batteries. Most guys buy the 975/1000 CCA batteries and that's a huge mistake. They cannot handle any sort of hotel loads.
    I shut my truck off unless it's colder than -5 F, I run a fridge year round, and have a bunk and engine heater. I also drive on some pretty crappy roads.
  4. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    A batterys life is only good for a certain number of dead cycles before it fails, it is especially prevalent in the high CCA batteries. I worked at a truck dealership, the warrenty returns for the 1000 CCA batteries was a lot higher than the 760's the 1000's have no space for the sluffed off material to settle.
    I have a 2007 GMC it has the original batteries in it, I do disconnect, the right front battery and with a regulated charger charge the batteries seperatly. Keeping the battery tops and all connection clean really helps.
    If you have multiple batteries you must change them as a group, changing one of three or even two does not work, you will cook the two new ones and the old one will be cold, and will not charge.
    Just a thought!
  5. heavyhaulerss
    3,723
    2,040
    Dec 23, 2009
    AL/TN BORDER
    mine last 3 years. ever since I been trucking. after 3 years, I'm running on prayers. I mean 3 years and maybe 1-2 months at most. but that has been my batteries life consistency. I have the napa 3100 series now. my last set of truck pro batt's took a dump at home on a sunday, only place open was napa. my new starter makes a huge difference in starting & a whole lot less battery draw.
  6. t600kw
    t600kw Bobtail Member
    25
    5
    Nov 6, 2013
    Yep, batteries rarely last more than 3 years anymore, my battery guy said feds make batt producers warranty their batts for 1 yr full replacement, after that nothing, recommends exide.
  7. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Better have them call Napa and Delco. No warranty at all for commercial trucks! They only warranty against defects. You can go to the Napa website and look up your truck, pick a battery then read the PDF.
    I've already gone through this with Napa and Delco.
  8. mtoo
    mtoo Road Train Member
    1,928
    4,427
    Jan 15, 2011
    Retired on bended knee
    I bought the high dollar Odyssey batteries Nov. 2011. Just starting my 4th winter. Very happy so far. When I go home for more than a couple of days, I plug it into a BatteryMINDer.
  9. ineedajob
    ineedajob Light Load Member
    231
    191
    Oct 18, 2014
    Trucks are running too few batteries for what is asked of them these days. It's no surprise.
  10. Skate-Board
    3,801
    3,995
    Aug 9, 2014
    Merrimack, NH
    Very true. I run a 110v 5cf fridge, 110v microwave, 32" flat screen. DVD player, Mr. Coffee and Airtronic/Espar heater.
    Batteries can only be discharged and charged so many times before they can't hold a reserve charge. I've spent many hours watching voltage and power draw. Biggest thing is a Mr. Coffee. Even with 4 brand new batteries all charged up a Mr. Coffee will drag your batteries down to 11.8 volts. I have an APU and run that whenever I use my coffee maker or microwave.
  11. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    our Napa had mentioned nothing of the sort, just bought 4 a couple weeks back.
