No marker lights when headlights are on
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by fuelman409, Mar 11, 2020.
  1. fuelman409
    fuelman409 Bobtail Member
    8
    Aug 29, 2019
    Texas
    2013 freightliner Coronado 132 Hey guys I’ve got a problem it’s got me stumped. Ok when I turn my headlights on I have headlights but no maker lights come on. Now when I hit the switch to turn only the maker lights on then they will come on all of them. I have replaced the headlight switch an still I have the same problem. Any thoughts?
  3. Klleetrucking
    Klleetrucking Medium Load Member
    378
    346
    Dec 11, 2010
    S.C.
    Only a guess but, bad ground somewhere?
  4. fuelman409
    8
    Aug 29, 2019
    Texas
    Thanks klleetrucking im running threw it now.
  5. Klleetrucking
    378
    346
    Dec 11, 2010
    S.C.
    A grounding problem will drive you insane. Keep everyone posted please.
    Bean Jr. Thanks this.
  6. Dave_in_AZ
    370,139
    Cab controller.
    Have you tried turning off the main disconnect switch for about 5 minutes to allow it to recycle?
  7. fuelman409
    8
    Aug 29, 2019
    Texas
    Yes I have tried turning off the main power an also disconnected the battery’s still nothing. I’ve checked all the fuses I’m not seeing nothing.
  8. fuelman409
    8
    Aug 29, 2019
    Texas
    Could the interrupter cause this problem?
  9. fuelman409
    8
    Aug 29, 2019
    Texas
    Marker light switch
  10. fuelman409
    8
    Aug 29, 2019
    Texas
    Tested the markers with the switch in the both positions They only light up when the switch is in the down position witch is running lights only
  11. fuelman409
    8
    Aug 29, 2019
    Texas
    Turns out it was the trailer marker fuse
    Klleetrucking Thanks this.
