No heat... Please help
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Rodneyb3001, Feb 14, 2012.
  1. Rodneyb3001
    Rodneyb3001 Bobtail Member
    9
    Nov 11, 2010
    I have a 2000 international 9200 with the Detroit 12.7 and I can't get any heat in the truck period.. I think my problem lies in the water temp in the engine. My temp gauge doesnt move at all in the winter.. It operates normally in the warmer months though. I've replaced the thermostats already. Any suggestions? Y is my truck not warming up?
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    On Detroit engines...there are 2 valves you can close for cold weather.
    Follow the lines from the radiator and close the gate valves.
  4. truckmechanic
    truckmechanic Medium Load Member
    534
    140
    Jan 14, 2012
    Hi Desert Ca
    Have you checked the gate valves for the heater hoses going to the cab if the temp gauge dosent move then I'd say you need to check the thermastat it sounds like its stuck open if the gate valves are open then the hoses running to the cab should be hot if they are then the problem is in the cab could be the rheastat on the control panel on the dash or could be the actuator for blend
  5. Kevin83165
    Kevin83165 Light Load Member
    143
    106
    Nov 24, 2011
    Herrin Illinois
    Just as Otherhalf said. I had this issue, one of my valves were closed. Follow the heater hoses in the engine compartment to find them both and make sure they are all the way open
  6. fortycalglock
    fortycalglock Road Train Member
    6,150
    6,581
    Jun 25, 2011
    Tourist Town, FL
    I have two sets of valves on the heater hoses. One set off the water pump and the return above the oil cooler. Mine look like hose spigot on my Western Star, but other trucks I've owned have had ball valves. I imagine if you don't have temp registering on your guage you have other problems.
  7. Rodneyb3001
    9
    Nov 11, 2010
    Ok... I failed to mention that both water valves are open... The blend door works.. The top radiator hose gets Luke warm and the heater core feels the same. Shouldn't the radiator fan not come on until the a/c is on or until the temp rises... Mine free spins and then blows fully only minutes after start up not allowing water to warm up... Already replaced thermostats.
  8. Heavyd
    Heavyd Road Train Member
    7,749
    6,184
    Feb 4, 2009
    Or the blend door in the heater box isn't working and stuck on cold.
  9. Heavyd
    7,749
    6,184
    Feb 4, 2009
    Yah beat me...
  10. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Do you have a water filter?
    When they changed the thermostats did they change the seals?
    Do you have a winter front?
    If you are in an area that is cold you may need a belly tarp, from the front bumper to the middle of the transmission.
    You want to also check the rad cap, if it is not holding preasure the system does not work properly.
    With the Cap tested and good, the system full of coolant, top rad pipe bleed, and the engine cold, oil level good, fan belts, and fan all good. Run the engine for 1 minute at Idle, you should buy an infered temp gun they are very handy, run the engine up to 1200 rpm and monitor the coolant temperature at the oil cooler housing, and the top rad pipe, it should stay cold, turn on you lights, pump the brake pedal, no cab heat, when the temp gets to 120 degrees, run at maximum RPM, and monitor the top rad pipe, it should stay cold untill the thermostat opening temperature, 190 degrees.
    If that tests out OK then turn the heater temperature control to full, lower the RPM to 1200, and check the shut off valve, works, and opens fully. It has a little lever and a cable, full out is on, full back is off. Measure the temperature out of the engine and into the engine threw the heater core, without the fan on they should be very close, put the fan on full, and measure the temp then.
    You may have a filter, in the air inlet for the heater that needs changing every year. the heater fans may be dirty and not work properly. remove them and wash if needed.
    Trucking is so much fun!
    otherhalftw Thanks this.
  11. Heavyd
    7,749
    6,184
    Feb 4, 2009
    So the fan is on 100% of the time after start up?
