No ground antenna on cascadia?
Discussion in 'CB Radio Forum' started by Mototom, May 9, 2021.
  1. Mototom
    Mototom Road Train Member
    1,388
    2,703
    May 7, 2019
    Dave_in_AZ Thanks this.
  3. mike5511
    mike5511 Road Train Member
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    It will probably work just fine. But, they are not very efficient, thus performance is not very good. I posted a link to a thread I started a long time ago about the Cascadia. The answer to your problem is in about the first 10 pages or so, if I remember correctly...... A 7ft SkipShooter and RG8x coax.
    Cascadia Antenna Solutions
    Meteorgray and Dave_in_AZ Thank this.
  4. Ridgeline
    22,103
    113,210
    Define work?
    work as in appearing to have a low swr?
    work as in allowing the driver to take 150 or more feet?
    Mototom Thanks this.
  5. Mototom
    1,388
    2,703
    May 7, 2019
    I’m hesitant to buy another 300$ radio and 100$ antenna. I’ve pissed away a good chunk already on trying to get a CB to work
  6. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    the road less travelled
    I've seen a long top loaded antenna secured to the back of the sleeper with grommeted supports to keep it from flexing against the body.
    I'm using the membrane above the cab in a high rise condo, and it works enough for me.
  7. '88K100
    '88K100 Road Train Member
    1,252
    2,625
    Aug 23, 2020
    Cascadia ? I took antennae mounts off a 5 year old Cascadia due to poor ground. Cleaned them up inside and out,,visible corrosion. Good now,I soaked the mounts in penetrating oil.... Difference on reading on my meter were quite obvious after soaking overnight
  8. 25(2)+2
    18,749
    45,384
    Sep 18, 2006
    Cascadia hasn't had factory mounts on mid
    roofs or condos since 2014, iirc. The 2013 had them. In dash radio has worked better on the newer ones, they seem to have fixed that, too.
    I have a mount but haven't bothered with it, I had run it though the firewall and concealed the coax in the 2013 I drove for 7 years. Had a 7 foot Firestick until it broke off the coupling, but a 5.5 Francis worked just as well, maybe better.
  9. Mototom
    1,388
    2,703
    May 7, 2019
    If I can get even a half mile to a mile of range I’d be able to make do
  10. mike5511
    3,139
    1,523
    May 15, 2011
    NW Arkansas
    Yes a low swr and at least 150 feet......maybe twice that!
    nredfor88 Thanks this.
  11. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    Two cans and a wet string. No fuse needed. Foolproof. :)
