No experience with an 18 speed, need to drive it home.
Discussion in 'Ask An Owner Operator' started by Thotphobia, Jul 30, 2021.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Hi guys, quick question, I’m about to drive a semi truck bob tailing from Texas to NC. I’ve never drove an 18 speed. I’ve been told I can just take it to 9th gear then flick the side button up and drive on home. Is this true? Can I go 75 mph like that? Sorry If Im not explaining myself correctly. If I’m not can y’all explain how to drive home bob tailing ?
    feldsforever, Coffey and D.Tibbitt Thank this.
  3. Cattleman84
    Cattleman84 Road Train Member
    9,871
    70,312
    Nov 1, 2017
    The Sticks, Idaho
    Yeah, if youre bobtail you can just shift it like a 9 speed, flick the switch forward before you even start your trip and forget about it... Leave the switch there and its a 9 speed.
  4. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    You can drive them just like a 9 speed, flip the splitter forward and go. I've driven mine that way loaded.
  5. Thotphobia
    69
    47
    Apr 21, 2021
    So before I get on the road, flick the switch up then drive it like a 9 speed? My cousin told me to drive it like a 9 speed once I get to the 9th then flick the switch .
    feldsforever and okiedokie Thank this.
  6. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    You can do it either way, bobtail it don't make no difference.
    feldsforever and Thotphobia Thank this.
  7. Team818
    Team818 Medium Load Member
    397
    626
    May 5, 2019
    Then 18 Speeds were the last stop over before the 12 Speed Autos, correct? Shift until 9/13, move splitter, and then its auto from there, up and down, until 9/13, then move splitter and shift down to stop after leaving the freeway and stopping at the bottom or the ramp? Or actually stopping anyplace. I have never driven a manual over 10. Glad Original Poster (OP) asked this question. Good to know.
  8. Thotphobia
    69
    47
    Apr 21, 2021
    So I’m guessing if I flick the switch before driving I’m in the highs ? And if I flick the switch last, I’m in the lows?
    feldsforever Thanks this.
  9. GreenPete359
    GreenPete359 Road Train Member
    2,144
    5,075
    Oct 21, 2017
    Driving my recliner
    The grey switch on the side…forward is overdrive, back is direct drive. Being Bob tail you can run in over drive all the way threw the gear box, so yes push that baby forward & run her like a nine speed
  10. Thotphobia
    69
    47
    Apr 21, 2021
    Ahh okay, so push that thing forward and leave it forward even when I stop?
  11. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Gears and switches are there to be used.
    Use em.
    Except for granny gear.
    I leave mine in overdrive due to the fact the speedo is lazy in direct. I climb hills at 15 mph in one position. When I'm doing 45 mph in the other position.
    feldsforever and baha Thank this.
